Had the kit in my 86 for about 4 years. Works flawlessly. I clamped it, adjusted it, spot wielded with the clamp on. Then removed the clamp and finished the wield. Did not have to cut the boot.
Adding on related question here...
My new-to me '85 911 has a seine shift kit and short shift installed. The 3-4 channel requires slight, right pressure to shift from 2 to 3, or from 5 to 4. Can I adjust somehow adjust to avoid adding pressure?? There metal tabs on the shifter are welded on. Thanks for any thoughts....Dave |
If you don't get the info that you need here, certainly contact Seine. Roger
'72 911 3.2 '18 Mustang Eco PP '17 Mustang GT Conv |
Undocumented User
From your description it sounds like you need a hair of an adjustment at the coupler in the rear not the actual shifter in the front. There are a lot of documented threads on how to do that. As already mentioned, in the 3/4 plane the shifter should slide into 3rd and 4th without any lateral pressure required since it should already be automatically "centered".
Also make sure the bushings are in good shape, etc.
FWIW, I also replaced the shift rod coupler with an aftermarket one (Stomski Racing, if I recall). This helped to provide for much more positive gear selection as well. Roger
