LinkBack Thread Tools Rating: Thread Rating: 2 votes, 4.50 average.
m1franck's Avatar
Porsche Crest Resurrecting Pearl '71 911T; a tale of “Restomodration”
After sitting under a car cover and up on jack stands for nearly three years it’s time to stop making excuses and resurrect Pearl.
Before the fun begins a little history;
’71 911T 2.2l light ivory/hellelfenbein 115k miles purchased in 2008 from Route 30 Classics in Mosier, OR. My wife took an immediate interest in this car, declared it as hers and named it Pearl. It’s good to have a spouse with interests like this.
We drove the car for a couple of years, while making various repairs and upgrades. In the fall of 2010 I decided it was time to replace the tired oil burning 2.2l with a low mile hot rod 2.7l that had been found locally. I began the replacement of the engine, then tripped, fell and began the tumble down the slippery slope of Porsche 911 “restomodration”.
The logic was as follows;
Since the engine is out for replacement, might as well refresh and upgrade the rear suspension. All of the bits were secured to install ERP poly bronze bushings, adjustable spring plates, hollow torsion bars, new dampers, alloy trailing arms and mono ball pivot bearings.
Since the engine and rear suspension are out this would be a good time to get rid of those later model rocker panel covers the previous owner had installed. Lets take them off blend the paint and be done with it.
Since the engine, rear suspension and rocker panels are off we might as well replace the replica fiberglass S front bumper and ducktail with parts that are less attention grabbing and more minimalistic looking.
Since the engine, rear suspension, rocker panels, bumpers and engine cover are off the car, we might as well do a bare metal repaint of the car, since it’s looking rather tatty and had been re-sprayed two times over the factory coat.
That’s where my attention, time and money became diverted on various family activities, household projects and business related work.
Fast forward three years and one day while in the workshop, for no apparent reason, I pulled back Pearl's car cover and started to work on the old girl. My wife noticed this unusual activity in the workshop and said “I’m glad to see you working on Pearl again”. Wow, what a great wife!
The plan for resurrection is as follows:
This will not be a factory to the numbers restoration. It’s just not in my style or nature to leave things alone and since I’m building this car for me, err I mean for my wife, then that’s the way it’s going to be done.
Bare metal to the tub repaint in the original light ivory/hellelfenbein. The car weighed 2180 prior to beginning this project and my goal is to be at 1999 or less at the completion of the restomodration. Removal of all unnecessary brackets and bits with the goal of lightness in mind. TRG fiberglass trunk and engine covers.
All new interior. Rear seat delete, RS carpet, light weight seats, etc.
All new front and rear suspension. Polybronze busings, Bilstein strut housings, Vonn dampers, hollow T bars, adjustable front and rear anti-roll bars.
Every nut, bolt and hose replaced as well as some other custom touches as the project progresses.
Below are a few photos of where this project started, some of the upgrades achieved thus far and where things currently stand. The attached link is a photo gallery of where many more detailed photos will be posted.
https://www.dropbox.com/sh/wddlv37ukhzi9l4/4Lbb9mPLIP
I’ll provide updates as progress is made, with hopefully no large gaps in time between those updates.
m1franck
Old 10-04-2013, 08:59 AM
m1franck's Avatar
The old 2.2 lump with the new 2.7 lump waiting in the wings
Old 10-04-2013, 09:03 AM
m1franck's Avatar
Rear trailing arms completed. Gone are the original steel trailing arms and replaced with '74 alloy arms. Lower shock mounts milled to provide clearance of shock body in upper shock mount point. All parts re-plated, ERP mono ball inner bushings, Wevo E-Z pin bolts, reinforced bearing retention plates.
Old 10-04-2013, 09:15 AM
m1franck's Avatar
911S front calipers and stock rear calipers resorted to perfection by PMB Performance. Stainless steel pistons and Porterfield R4-S pads.
Old 10-04-2013, 09:19 AM
m1franck's Avatar
E brake handle assembly restored. All parts stripped with glass bead and powder coated.
Old 10-04-2013, 09:23 AM
m1franck's Avatar
Pedal cluster restored. All parts stripped with glass bead and powder coated. All new bronze bushings and springs.
Old 10-04-2013, 09:28 AM
m1franck's Avatar
Steering rack rebuilt. All new bearings and spherical tie rod ends.
Heater flapper boxes stripped, powder coated and re-plated.
Old 10-04-2013, 09:38 AM
m1franck's Avatar
Rear bumpers. Trim holes filled, built filler plate for leading edge of bumper to replace the original alloy trim piece that would normally attach there.
Old 10-04-2013, 09:59 AM
What?
Eric Hahl's Avatar
Nice!
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 10-04-2013, 10:05 AM
Very nicely done ! Looks great.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-04-2013, 10:07 AM
docrodg's Avatar
WOW!!!! Very nice.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 10-04-2013, 10:12 AM
m1franck's Avatar
The wiring harness was removed from the car last night. Some say it’s impossible or very difficult, to me that sounds like a challenge. Yes you can snake this harness from the back of the car, forward through the tunnel and out through the trunk. Some minor disassembly of the engine compartment connector heads were required, but nothing major. Also, the factory plastic sheath was removed in order to slide the harness wires from the right side of the torsion bar tube to the center where there was enough clearance to pull it clear of the torsion bar tube.
The harness itself is very simple and it’s likely the headlights alone on my daily driver BMW have more wires than the entire 911 harness.
Old 10-04-2013, 11:11 AM
1980SCMan
Alan Lindquist's Avatar
This car will be beautifully finished - I can tell that already. Subscribed.
The car will be valuable. Your wife, on the other hand, is priceless.
Old 10-04-2013, 12:06 PM
pete3799's Avatar
This is going to be good........can't wait.
Pete
79 911SC RoW
Old 10-04-2013, 12:13 PM
AutoBahned
RWebb's Avatar
quite a job!
but to get below 2,000 lbs. with steel R. bumpers will be difficult
Old 10-04-2013, 12:16 PM
poorsha's Avatar
Very nice work.
Subscribed
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 10-04-2013, 12:26 PM
andy_uranium's Avatar
Looks amazing so far! Subbed for future progress.
DD - 2011 VW MK6 GTI - Candy White
Currently seeking a 911 Carrera or SC
Old 10-04-2013, 03:18 PM
fasterlaster's Avatar
It's looking good already. Subb'd
1974 Porsche 911 Targa w/ 3.2L
1989 Porsche 964 Carrera 4
Old 10-04-2013, 08:06 PM
m1franck's Avatar
Made some more progress today. Removed the front and rear windows, dash pad and some more interior bits. The good news is no rust in the bottom corners of the either window frame. The back window has a 2 stage defrost element. Top and bottom sets of elements turn on separate from the middle set of elements. I’d like to convert this to a one stage defrost and in doing so eliminate some wires from the wiring harness. Does anyone know if there would be any problems with circuit overload if all 3 elements operate simultaneously from the first position on the defrost switch?
Old 10-05-2013, 02:15 PM
Jim Horton's Avatar
Let me know if you need any help with grunt work.
Jim Horton
1970 911T
1971 911E Targa
2006 Porsche Cayenne
2018 Tesla S (blasphemy!)
Old 10-09-2013, 02:37 PM
