sensor question
can someone tell me what these 2 sensors are?
![]() ![]() the first one is on the left side of the engine compartment and the second one is on the right side. Thanks, david |
The one to the left side is the cold start injector que
To the right of the fan is oil temperature Bruce |
Fleabit peanut monkey
Meaning it is the interface between how warm your engine is and whether or not CIS needs to spray extra gas through the cold start valve on the back side of your engine.
Engine hot, no need for an extra spritz to get her going. Actually, it's pretty robust when the CSV sprays. Sensor is also called the thermotime switch. It's more of an on off decider - hence the term que.
1981 911SC Targa Last edited by Bob Kontak; 10-09-2013 at 08:31 PM.. |
thank you!!
Sorry to jump in ..
So when converting over to Webers the sensor to the left can be disconnected.. ? |
Vintage Owner
Thermal time switch
It shouldn't be needed if you converted to Webers. However, it sure would be nice to be able to choke down the Webers when starting from cold as your leg can get quite tired keeping the engine running until the Webers are able to keep it going!
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
