Exclamation Mouse damage!
I just began digging into my new project car, a 73 911 coupe.
I removed the drivers side floor board to expose the pedal cluster and found a wire harness (about 3/4" round) with several wires chewed, and damaged by mice.
About 7 wires are destroyed in this area.
My question is, should I splice new wires in? Or replace the entire harness?
I will also need to know if this is the main harness? or what it is called. (to find a new one.)
Thanks.
Old 08-29-2001, 05:10 PM
Post
expose the wiring by slitting the harness, replace one section of wire at a time (match the colors) solder them and use heat shrink tubing to insulate. then tape up the harness. nothing wrong with a proper repair job. wire crimps in a harness are not the best way to fix it.
Old 08-29-2001, 05:51 PM
Post
I will attempt to solder them this weekend-thanks for your advice.
Old 08-29-2001, 05:58 PM
Toxic
derkpitt's Avatar
Post
In aviation we use wire crimps all the time. It's better than soldering and faster. Just make sure your using AMP type splices, with the right tooling. Not the cheap automotive type. Do you know any Aircraft mechanics?
Derk Pitt
88 Carrera Coupe
Old 08-29-2001, 06:18 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Post
my experience is that crimps tend to pull, but I've used both. Of course, crimps done right don't pull as often. I would recommend in this case soldering anyway and shrink wrapping around it. It will look the most professional to the next owner who will no doubt view yor handiwork.
Old 08-29-2001, 08:42 PM
Senior Member
Post
David,
If you have had a mouse in one part of the car, you may have had more in other areas.
Check the pic out on my website and you will see what a mouse cost me. Worth taking a flashlight and looking just in case!
Joe
http://pws.prserv.net/usinet.joeaksa/porsche1.htm
Old 08-30-2001, 04:24 AM
rstoll's Avatar
Post
Hey Joe, I hear your Rat damage could have been prevented by Mobil 1.
Robert Stoll
83 SC
83 944
Old 08-30-2001, 04:45 AM
Senior Member
Post
Robert,
You are totally correct, however it was a mouse! You hold the critter and I will dunk it in Mobil One (or Castrol for that matter), then we can both light the match... and stand back!
Since its your idea, lets try it on your car first!
Joe
Old 08-30-2001, 05:31 AM
Senior Member
Post
Robert,
Forgot, if anyone runs out of Rogane, Mobil One works well in this area as well! I have tried it for years and while I am still bald, the fuzz keeps growing enough to make me go to a barber every couple of weeks.
Spread the word!
JA
Old 08-30-2001, 05:36 AM
rstoll's Avatar
Post
Let's see now.....WD-40 for my arthritic knee and Mobil 1 for my bald spot. Got it!
Robert Stoll
83 SC
83 944
Old 08-30-2001, 08:39 AM
Angry
How do the little bastards digest copper?
Old 08-30-2001, 09:31 AM
Saffs's Avatar
Post
I had a mouse in my old '81 BMW M535i. As well as eating some wires it ate the MOT certificate (UK certificate equiv. to US inspection) and my insurance papers for it that I'd stupidly left under the seat - only left the car in airport parking for 3 weeks.
If I got stopped by the Police I was prepared to say a mouse ate my docs....
'75 911S Targa
'81 BMW Alpina C1 2.3
Old 08-30-2001, 09:48 AM
rstoll's Avatar
Post
I think their tiny system can process a Brillo pad.
Robert Stoll
83 SC
83 944
Old 08-30-2001, 10:09 AM
Senior Member
Post
David,
They do not eat the wire, they love the insulation around the wire. Course the whole matter is made worse by the droppings they leave, as the area is now filled with mouse crap and where ever they pee it stinks and does wonders for the metal.
Robert, its VIAGRA for your knee...
Joe
Old 08-30-2001, 12:37 PM
Senior Member
Post
David,
Also, was at a shop two weeks ago and they were getting ready to crush a 911 that was terminal. I took all the wiring harness out that I could get to easily. Try to find a wrecked car and get the harness, that way the wires you splice into the harness are the right color code and size!
Joe
Old 08-30-2001, 12:39 PM
rstoll's Avatar
Post
Is the main ingredient in Viagra really Micoxaphloppin????
Robert Stoll
83 SC
83 944
Old 08-30-2001, 02:54 PM
Thumbs up
Wow -crush a 911? NO!
Tommorow?- I solder! I will splice the wires and use heat shrink.
I will also use Decon rat pellets, Swiss cheese and a good old mouse trap!
I will let you know what I catch!
Old 08-30-2001, 06:41 PM
Post
Well, I spent 4 hours on my back today with a hot droplight next to my face, and the fumes from the hot soldering gun in front of my nose.
I found that the little RAT lived in the tunnel. He had newspaper, hay,and all kinds of sh-t in there.
I cleaned it out, soldered, and heat shrinked!
Alot of work, but I really enjoyed it..
Old 09-01-2001, 04:22 PM
Senior Member
Doug Zielke's Avatar
Post
I can loan out one of the "girls"....
The Lynx-Siamese are especially tough on rodents! (Or anything else that moves.)
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
[This message has been edited by Doug Zielke (edited 09-02-2001).]
Old 09-01-2001, 06:26 PM
