Fog lights not working
I have a 1984 Carrera and I recently installed a headlight relay kit from JWest and replaced my h4 bulbs with 80/100 watt Osram/Sylvannia bulbs. Everything works (dash lights, park lights, high beams low beams) except my fog lights.
-fog lights worked before the relay installation, although the switch never lit up when pulled -checked the fuses #20 and 21 and just replaced them just in case -made sure the fog light relay is working by swapping with the horn relay -checked the fog light bulbs and they looked clean with no dangling or discolored filament I recently replaced the dash lighting so I was familiar with pulling the gauges and I peeked through the clock hole. I can see that the fog light switch had one prong that does not have anything connected to it. Does anyone know if the fog light switch should have all it's connectors utilized? I am thinking that maybe a connector got pulled. Furthermore, how can I access the wiring behind fog switch area? By removing the stereo? Seems to be solid housing underneath. Any help is much appreciated!
AJ 84 911 Targa, 76 911 Targa, 2014 Cayman S, 77 280z |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Jwest connectons.
![]() ![]() ![]() ^^^^^ Connections ![]() ![]() ^^^^^ And, here is how you can use your foglights independent of your headlight switch. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Gerry,
Thanks, I researched this topic in the forum and came across your pics and diagram which are very helpful. My relay setup matches yours. I may try extending the gray wire in the #20 bottom fuse panel to #11 and see if that works. I think my issue is originating at the fog light switch itself.
Little grey wire.......
That is most likely the wire that provides power to the trip side of the fog light relay. If you want the fogs with low beams only, just move the grey wire to the bottom (out) side of the low beam relay fuse. If you want fogs anytime, move to the out side of a fuse that is always powered. Don't worry about the load as it will only pull a fraction of an amp.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Does anyone have experience with the fog light switch wiring? I am attaching a pic I found in an old forum. I am trying to find out if all the prongs should be connected? I also mentioned that my switch never lit up so I am assuming that the light bulb either burned out or got disconnected.
Looks like all terminals on switch should have connection. On diagram for '88 the fog light switch shows the following on switch terminals, as shown above by '86 Targa:
#1-white wire -fog light relay terminal #86 #15 -green/white wire- light switch terminal 'J' #31 - brown wire - ground #58 - black wire - indicator lamp in switch
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
I believe you have to remove the fresh air blower and plenum from the front trunk to get at the switch. Unscrew the knob and use a small needle nose pliers to unscrew the black retaining collar. You can then remove the switch from behind.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Fog Lamp Knob: Fixable? Maybe there is also some useful information about the fog light switch wire connections for you. I am not very knowledgeable about the wiring. But I remember in Germany there are restrictions on when the fog lights can be turned on. For instance they cannot be lit with the high beams together. Porsche the made the fog light wiring so that cannot happen. That situation could have something to do with your relay installation. Because the factory wired the cars in a way that fog and high beams cannot be on simultaneously. I am writing this all from memory. Maybe somebody else with fog light experience can chime in here.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold Last edited by porwolf; 10-14-2013 at 08:12 PM.. |
So I was able to finally get access to the wiring and everything looked fine. My switch has 5 connectors, and does not have a middle space for a bulb, so perhaps it never had a light. My switch looks like the first picture below and not like the second switch which has 4 connectors and a center light space.
I guess, I am back to square one in terms of diagnosing the problem. I might remove the headlight relay and see if i can get it to work like it did before. ![]() ![]()
Thread Tools | |
Rate This Thread | |
