Speedometer. HELP
The other day my speedometer needle started to get twitchy, erratic, then it just died and the the odometer s failed as well.
So is it electrical or gauge gear wheels worn out.
M-74
Old 10-15-2013, 06:44 PM
DRONE's Avatar
Sounds like it isn't getting a signal (electrical) easy enough to pull out the speedo and check the connections.
I just had to have mine repaired because of worn gears, odometer quit but speedo kept working.
Old 10-15-2013, 08:08 PM
crustychief's Avatar
What year is it? Based off what you said the wires may be coming loose off the sending unit on the transaxle. But it could also be a speedo cable that broke, depending on the year of the car.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-15-2013, 08:34 PM
Hell Belcho
Nostril Cheese's Avatar
What year and model do you have?
Could be a bad speedo cable, bad sender, wiring issues, gauge needs service, etc..
Functionista
manbridge 74's Avatar
I've done two 74 speedos and am betting on cable coming unplugged or breaking. Mine were odo not turning but speedo was fine.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-15-2013, 09:11 PM
Originally Posted by nostril cheese View Post
what year and model do you have?
74 911
M-74
Old 10-15-2013, 11:22 PM
