Speedometer. HELP
The other day my speedometer needle started to get twitchy, erratic, then it just died and the the odometer s failed as well.
So is it electrical or gauge gear wheels worn out.
M-74 |
Sounds like it isn't getting a signal (electrical) easy enough to pull out the speedo and check the connections.
I just had to have mine repaired because of worn gears, odometer quit but speedo kept working. |
What year is it? Based off what you said the wires may be coming loose off the sending unit on the transaxle. But it could also be a speedo cable that broke, depending on the year of the car.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Hell Belcho
What year and model do you have?
Could be a bad speedo cable, bad sender, wiring issues, gauge needs service, etc..
Saved by the buoyancy of citrus. |
Functionista
I've done two 74 speedos and am betting on cable coming unplugged or breaking. Mine were odo not turning but speedo was fine.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
M-74 |
