Dear Friends
I would like to know what are these 4 screws ( and I just red circle 2 of them, the top ones) on rear and the left hand side of this 1983 3.0L engine block Mine are badly corroded and today i unscrew one and notice that its not just a bolt, it's long and looks like a pin or something, it has a aluminum crusher washer on it Also I would like to know if I damage or misaligned something when i made this exploratory removal Regards |
I would rather be driving
cam chain ramp fixing bolts. You risk issues with the cam chain alignment and support ramps by moving those bolts. By pulling them out the plastic ramp becomes distorted and my not fit tight.
NOw you need to pull the cam chain cover and replace the ramps.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Member 911 Anonymous
or Worse broken plastic pieces inside the engine. That rust in only surface rust.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Just to echo the first two guys, you must at minimum, install new chain guides. The risk of not doing it could be a very expensive repair.
1986 Targa Guards Red 2021 MT09 SP |
Stop exploring!! Without a manual, at least the motor is out of the car.
It's possible that the chain ramp didn't move, and putting the pin back in will be fine, but he'd have to do some exploring to verify. Actually, test is this: 1) Try to put the pin back in. if it only goes in about 1-2 centimeters, then the ramp is blocking the hole and you need to open things up. 2) If the pin goes in more than that, do you feel some tension putting it in, like you are passing a spring loaded detent? That is good, since the chain ramp does have that. 3) If you put the pin back in and it just slides all of the way in without any tension, then the ramp has shifted away and you will need to open things up.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Chain fence eating turbo
![]() ![]() ![]() ![]() ![]() Just kidding, don't do that. A joke
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Dear Friends
Thank you all so much for the input! I'm so sad and embarrassed that I messed up with this bolt...Anyway, now it to late Let me just give you all more info The engine still in the car (the pictures of this engine was a file picture for demonstration poorhouse) I understand that now i must open the chain cover to double check if its assembled right and once its opened change the plastic chain guide, but... I actually just unscrew 1 screw (the bottom left side the that I circled on this new pictures) And when I reinstall the bolt it went well all the way in, but at that time I did not paid attention about the a tension against the bolt. So my new question is, when I remove just this one bolt, it possible that the chain guide shifted? And now that I'm screwed already, just open again this bolt and try to reinstall it trying to feel this tension? Thank you all again
With the chain housing cover off, you can inspect and see what you are doing while reinserting the chain rail.
Might as well take both bolts out on the rail, remove the rail, and inspect the holes the bolts went through. I broke 1 removing on my last teardown. Easy to do. Luckily, they're only $6 a piece.
Removing the chain housing cover with the motor in the car with engine tin installed must be a major pain in the ass!!!
Really not that bad once you remove the rear tin, which is also not all that bad to take off either.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
