Speedometer and Odometer stop working
Hi...
Couple weeks ago, my '89 Carrera 3.2's speedometer and odometer stop working on my way home all of a sudden. Later I browsed some previous posts on Pelican forum so I replace the speed pick-up sensor first. Unfortunately my problem did not solve, so I borrowed a working gauge from a friend of my, and put it on my car to give a test.
The result is the same...lights are working but speedometer/odometer are not.
So I took my meter to measure the sensor output from the tunnel, and I did not have any output from those brown/green lines.
Kindly asking any suggestion what should I check next...
Thank you all.
Old 11-03-2013, 11:42 PM
It sounds like you have a loss of continuity in the wiring. Start at one end and physically examine the wires to the other end.
JR
Old 11-04-2013, 05:08 AM
The Bavarian
If both instruments stopped at the same time you will have to look for a common source of failure such as missing +12V or ground. The two instruments use totally different sensors, so that cannot be it.
Just a thought, Manfred
'80 911 SC Targa black/black
Old 11-04-2013, 05:17 AM
Thanks for replying guys!!! Problem found!!! It turns out my fuel pump's outlet is leaking, and gasoline somehow affect the speedometer's ground just slight right above the fuel pump. After I put on a new fuel pump, both speedometer and odometer run again.
No wonder I smell gas fume from time to time while driving.
What an odd problem solving experience!!!
Old 11-05-2013, 01:17 AM
