3.2 '86 HP increase
First, I searched the archives but couldn't find the info I seek.
My '86 targa has a Steve Wong chip, M&K pre-muffler and 1-in, 1-out muffler, which are great baseline improvements. My question: What are the next logical group of improvements to enhance performance by a significant amount, while maintaining reliability? I'd guess this involves some combination of increased compression, displacement, twin-plugging, cam change, and chip mapping. Any views of particular combinations of these changes, or anything else? Thanks, Jeff |
Chain fence eating turbo
Pieced together stock 930 turbo bits!
RETIRED
Suspension tweaking and driving classes.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Undocumented User
You've pretty much exhausted the low hanging fruit... like others have said, learn to drive the car to its limits or focus on the suspension because further engine upgrades are going to be expensive and net you little in additional power.
Agree with others . . . OR - - - sell it and buy a 964 or 993 or 996 Turbo . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
durn for'ner
Weight reduction.
Markus Resident Fluffer Carrera '85 |
Shorter transmission gear ratios. But this cost $$$
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Keep what you have and put on some seriously sticky tires, maybe some performance brake pads, send your struts out to be rebuilt, replace all of your suspension bushings....then invest in some track time.
I think that as our cars age, it may be more prudent to get our rides baselined as stuff wears out. That will provide a reliable driving experience.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 Last edited by CCM911; 11-05-2013 at 06:15 AM.. Reason: spell |
Banned but not out, yet..
An air cooled refrigerator. ‘Mein Teil’ |
Grappler
I would say his list is spot on, but by the time its finished he could have purchased a nice 3.6 for less. Or as Tippy said, join the boost club.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
The problem with the 3.2 is the smog cams. Cams with more overlap will not work with the fuel injection. If you make it breathe you will get a lot more power and throttle response but it will be at the expense of emissions and fuel economy. Some cams with aggressive valve overlap, 46mm PMO carbs or EFI, and headers with a sport muffler would make it scream. If you want to go even further you will need higher compression and dual plugging. It gets very expensive quickly. Or, as others have suggested, add a turbo.
As others have suggested and depending on your particular engine condition/value and budget, a 3.6 or an already rebuilt modified engine might be a better starting or end point. Sherwood |
Thanks, guys, for the useful info. BTW, I have addressed the 'low hanging fruit' re suspension ... Bilsteins, euro lowered, aligned, corner balanced, Dunlop Direzza tires. The engine thoughts are dreams for the future. John Walker's shop is just a hop and a skip from my house
![]() What set of mods is required for a turbo upgrade, or is the option to just replace the car? |
Replace the entire car with a newer model or a turbo if you want more power.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
. Also I see inumerable posts here by folks who have $$$ modified engines, so I'd guess I'm not the only one to consider diving deep in the pool of economic foolishness
I would rather be driving
The next simplest engine upgrade to retain NA would be:
98mm high compression pistons/cylinders (makes engine a 3.4) 993SS cams (probably won't pass smog but will work with Motronic) twin plug heads (necessity due to bore and compression increase) custom chip to make it all happy. This would be a great engine. Next from there would be to go to a bigger cam. With a bigger cam you need an new engine managment that does not use a barn-door style AFM. You could use manifold pressure (MAP) or mass air flow (MAF) as your new metering device. If you go to a new EFI system you might as well go for the ITBs to make it really scream. Look at the recent post from D-Zug about the torque (and HP ) increase from an ITB setup. Its a steep slippery slope. Have fun on the way down.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
ITB = Individual Throttle Bodies, such as what PMO sells to replace your whole intake system..
Gary R. |
porsher
It's such a difficult trade-off between power, reliability and cash.
I like reliability with my power, so I went the 3.6/G50 route. To avoid the cash issue, I never add up all the expenses!
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
