Any idea why my fan doesn't work?
My 84's front de-misting fan doesn't work. Is there a common problem I should look for? It all looks connected, I've checked the fuses yet still nothing. Before I take it apart I wondered if anyone here knows of a common problem?
They self destruct quite frequently.
Do a search for "fresh air blower"
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
De-misting MUST involve lowering the relative humidity of the cabin atmosphere, specifically that at the surface of the windshield or flowing across same.
In most cases that involves HEATING the cabin atmosphere to lower the Rh, relative humidity, and/or lowering the windows slightly in order to more quickly PURGE the high humidity cabin atmosphere. FORCED fresh inlet airflow AND OUTLET AIRFLOW will abate the rise in cabin Rh due to human metabolism thereby significantly lowering the onset of interior windshield surface fogging. But once condensation has formed, or begins to form.......HEAT! And let's not have some I@#%$ suggest using the A/C, the A/C in our 911's is ALWAYS in recirculate mode, plus, BIG PLUS, mother nature may not be in the mood to be co-operative. Oh, the only time I have even been tempted to use the fresh air blower in my 78 Targa is with top on as a shade from a hot Kansas sun at mid-day. Don't think that I have ever considered using it at all in climatic conditions conducive to windshield fogging. Last edited by wwest; 12-13-2013 at 07:32 PM.. |
Yes, VERY common failure, mostly results in loud squealing as the bearings begin drying out. Had I known at the time when mine was complaining loudly how useless it would prove to be I would have simply disconnected it rather than DIY repair. Perhaps that's what your previous owner did? |
Just to be the I@#%$ as noted above, one of the attributes of air conditioning is dehumidifying especially when no new humid air is being introduced(recirculated air).
1989 Diamond Blue 911 Targa 8000mi and counting 1976 Saab 99 2011 F-150 Ecoboost |
Banned
I found it useful in my old targa and it was annoying when it didn't work in my coupe. When i move the slider it does nothing at all. Is there a common place they get disconnected?
Assuming you have no blown fuses... There is a connector in the bulkhead between the interior of the car and the trunk. Follow the wires from the ventilation controls to find it. If all is well there, you probably need to get a wiring diagram, a multimeter and have a look at the blower motor.
JR |
Hey wwest..did you take your medication today or are you practicing using big words :=)
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fan.
I agree with javadog, here's the ckt for your car.
Good luck, Gerry pm me as needed.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I need to remove the fresh air blower motor from a 77 930. Anything I should know if advance? Hard to do?
Jeff Fort, Findlay, Ohio 70 914-6 2.7 07 Carrera C2S 05 Cayenne V6 |
It's just like any 911. Not hard to do, just a little time consuming. There a a zillion threads already, so a search might be helpful.
This thread has some info that might help, towards the end: Retrofitting non-A/C ventilation ducts JR |
looks like you take the clips off that hold the two halves of the housing together. found the motor for $85 using a thread from another PP thread. hope to get at it this week end. thanks for the response
You're the man, javadog. It looks like the instruction I needed to remove the fresh air blower is on page 4 of your referenced thread. Wish me luck.
I wish you luck.
It's not all that hard. Just don't let any of the little rings fly off into a dark corner.JR |
