VFR750's Avatar
Worn Trailing Arm Mount Bolt Hole - Is this common?
The mount bolt must have been moving enough to imprint the threads in the edge of the hole. The bolt threads were flattened a little too.
Is this common? What I thought was a worn out mono-ball is looking more like the bolt joint loosened a little, enough for the assembly to move about. This could explain the odd straight-line instability I had. Just a hint of wander, that went away as son as I loaded up the supension in a turn.
Any good way to fix this, short of replacing the mount point? Enlarge the hole and put a sleeve in it? Flanged sleeve?
I saw the WEVO replacement, which would be nice, except the hole would still be a little loose.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 11-26-2013, 11:43 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Weld some thick washers on the outer part of each mount point and use a longer bolt?
Kevin L
'86 Carrera "Larry"
Old 11-26-2013, 12:44 PM
GaryR's Avatar
Send a message via ICQ to GaryR
I was thinking similar - weld up about 1-2mm of the elongation, then weld a hardened washer with the correct diameter hole in place on the outside, then use a drill to cut away any excess weld, then use 10mm longer bolts.. but it's easy for me to say..
Gary R.
Old 11-26-2013, 12:50 PM
VFR750's Avatar
I looked at some stock washers, and they are not that close of a fit. The best fit was a washer for a 12mm bolt, and the hole would have to be opened up a little. The ther problem was the OD was too small.
So on a hunch, I cleaned up everything, relubed the mono-ball, and reinstalled the trailing arm. Torqued the nut to 72 ft-lb (100 N-m)
Now the joint is tight and all the play is gone. The mono-ball moves freely, with no apparent slop. I looked very closely at the bolt, and there was no sign of distress, other than the wear on the thread.
What is odd, is the washer used was a spring (wave) washer, and does not appear the washer was fully compressed. The marking indicate local contact. Porsche does not call out a spring washer in this location. I'm thinking maybe it is the wrong type for this location.
Anyone know if this is a wave/spring washer: N-011-534-04 PP does not list it.
Mike
Old 11-26-2013, 01:22 PM
