I heard ND 02 sensors reacted more quickly than Bosch, and give better response.
Old 02-28-2007, 09:20 AM
kuehl's Avatar
Old 03-03-2007, 04:11 AM
I thought the O2 through the wire was crazy also and then I looked for a sensor to prove that correct.
Edit from here on...hit the wrong button.
You can see the black wire goes into the sensor (sealed) and that is a very expensive rubber cover for that cheap spade connector at the other end. Maybe the Bosch design does get O2 through the cable. I don't remember which car this sensor is out of.
Old 03-03-2007, 09:17 AM
Czar of C.R.A.P.
dfink's Avatar
Well I am glad now that I revived this thread 5 years old now. I really thought I would get blasted. Perhaps Wil should re-contact his original source let to let him know there is a crack in the ice. It might be interesting to dissect one of those fancy Porsche connectors and see if there is are any ports or tiny felt filters or such. But that connector is apparently not available so If you have a good one I wouldn't chop it up.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 03-03-2007, 09:53 AM
Wavey's Avatar
The thread that wouldn't die!
Just bought a Bosch Universal and the directions specifically say:
"Do NOT solder wires. Soldering wires will lead to early sensor failure."
Comes with a super-fancy sealed connector to splice into the original sensor harness.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 04-21-2010, 03:04 PM
muck-raker
kidrock's Avatar
yeah Wavey, I picked up the same model about a year ago. No problems.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-21-2010, 03:48 PM
Very interesting thread. and i thought I knew a lot about O2 sensors! By the way they put out 0 to 1 volt. The new widebands have a much larger range and are much faster. I think they do 0 to 5 volts if I am not mistaken.
I bought a Bosch single wire for my pickup truck a couple weeks ago.....$18.00 at pep boys. simple one wire connector.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-22-2010, 07:01 AM
Wavey's Avatar
Yeah, I looked at using the Ford part number referenced in this thread, but it was the same price at AutoZone that I could get the Bosch Universal for.
Old 04-22-2010, 07:03 AM
