Outer fan pulley half worn out?
Am new to Porsche world; just bought '88 911 3.2 with G50. Previous owner had done much recent work, including new belts. But found fan/alternator belt very loose. Read many threads on this; removed nut and found all 6 shims on outside under cup washer. Belt was NAPA and couldn't verify on NAPA site that it was right for the car, so ordered correct Contitech from our host. Same story. Outer pulley half goes on fine. Belt is in the right groove on the crank. I tighten nut a bit at a time and crank the engine in between to ensure belt is seating. Tighten nut to the 30 ft-lb spec. But even with all six shims on the outside, belt is still way too loose -- getting nearly an inch of deflection. Outer pulley half doesn't LOOK particularly worn, but is there some measurement I can take to verify? Is it possible that the fan is in too far on the shaft, i.e. is there possibly some spacer missing that should be behind it? Is there a measurement spec for how much shaft with threads should be extending out beyond it? Frustrated; don't want to drive the car, knowing how important adequate fan cooling is, but dying to. Thanks for any suggestions.
Test assemble without the belt in place and check the pulley outer is pulling up tight against the fan pulley section. Start out with 3 washers in between and 3 out and try again. Photos might help others to help you.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Many people are having trouble with the Conti belts being to large.
Get a different make belt and try it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Go with a Dayco belt. If I remember correctly the size is 15280. I'm not sure if Pelican stocks this or not. I have had no issues with this brand of belt.
Dustin |
Get a factory belt.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Taking it apart is easy
There is another very recent thread on changes to Conti belts. I believe it was John Walker who said that Conti belts with white lettering on them are newer and of poorer quality.
The older style belt with yellow lettering is the better quality, if you can find them.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fan belt.
Here's what we have, W/ yellow letters:
![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Damn. I just checked and I have a white letter Conti belt (new). I'm going to look around for a yellow letter one.
Is it really the belt quality?
Thanks to all who replied. Mine is the white-lettering Conti belt. This begs two obvious questions:
1. If the white-letter belt is known to be a problem, why are people still selling it? 2. Are you kidding me??? A belt manufacturer's quality control is so bad that they can't even get the length right? Thought the auto industry had this one down about a hundred years ago... What next; out-of-round tires? Before I go buying (yet) another belt, just to address some of the other suggestions, I did take the belt off and re-assemble things with all 6 shims on the outside of the pulley half, under the cup washer and nut. The pulley half DOES seem to seat properly all the way against the half on the fan. Will include photo below. Will try to find another belt, but really wondering if something else is going on here...
The genuine Porsche belt is only 10.67 retail. Buy one and your problem will be solved. I quit using aftermarket belts several years ago,they just don't fit.
Howard
Member 911 Anonymous
+1, oem will not fall apart on you either, ask me how I know.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Here's today's stupid question: Where do you get a genuine Porsche belt? PP doesn't have them, and there is no Porsche dealer anywhere near me since Porsche killed the one dealership that was in this region.
Pelican shows both lengths of alternator belts in stock. Part number 999-192-176-50-M100 for 9.5x7.10 and 999-192-097-50-M100 for 9.5x7.25. Brand for both is Genuine Porsche.
For what it's worth I've got a NAPA belt on mine. It's been fine for 3 years now.
Pelican can supply any part Porsche sells. Call them and ask for the belt by part number. Or, buy it from a dealer that will ship parts. There's umpteen of those, just a phone call away.
JR |
See, I got the stupid part right... Good way to get advice, evidently.
Thanks for the info. I was going to use a three-year-old, but good, yellow lettered Conti on the car and keep the white lettered one as a spare. I'll get a Porsche belt and keep the yellow Conti as a spare.
Sooner or later, the spare will be too old to use. Another strategy might be to use the spare each time the belt is changed and replace the spare with a new one. Assuming you are not starting out with an old spare...
I'm also assuming relatively frequent belt adjustments and replacements. If you wait until the belt breaks, that's too long... JR |
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
NAPA belt
Pete3799 mentioned his successful use of a NAPA belt. Actually, mine had a new NAPA belt on it when I got it and it, too, was too loose even with all the shims on the outside. Just curious as to what NAPA part number you've found to work. Mine was a Premium XL 25-7280.
800 726 9155 Brumos Porsche
