need part # for this plug
just used the last one and didn't write down the number. used to plug the oil pressure sender hole in the sender mounting block between right cam oil line and engine case on early cars that don't have the pressure sender mounted there, when doing the tensioner update with the short cam oil line. may have other uses, like to plug the large sender hole on top near the bellhousing. pet didn't help.
206 637 4071
Old 11-29-2013, 01:35 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
I think they are a Standard o2 bung plug , don't think it's a pet part.just used it for same purpose on my last build.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 11-29-2013, 02:00 PM
I have 2 different part numbers for that plug.
I think the difference is one is aluminum and the other is some kind of aluminum alloy.
here's the numbers
900-219-009-30
900-219-020-31
The first number is the one I have listed for plugging the oil sensor port.
It is also used on 928 & 924 cam housings and Boxster/water cooled 911 oil drain plugs, and I'm sure other applications.
As SCOTITUDE said, it's also the same size as an O2 sensor bung plug.
Old 11-29-2013, 07:12 PM
kodioneill's Avatar
Looks like a Mercedes oil pan plug.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-30-2013, 07:24 AM
this one is steel.
206 637 4071
Old 11-30-2013, 09:01 AM
I was digging through my parts and found a metal one.
Here's the part numner for the metal version:
900-219-015-00
Old 12-17-2013, 11:10 AM
awesome, thanks.
206 637 4071
Old 12-17-2013, 11:20 AM
Senior Member
Jdub's Avatar
18 x 1.5 as I just used on the O2 sensor bung on my bypass pipe, '78 non-O2 exhaust:
'78 Targa in Minerva Blue
Old 12-17-2013, 11:29 AM
djpateman's Avatar
What is the thread size & pitch? I know of a VW part that is 10mm x 1.0.
Oops, missed the size posted above.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-17-2013, 01:15 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
John...found some of these M18 X 1.5 plugs.
Located ********.com....part # 107 .... $1.22 each.
I think they are in the U.K. but online too.
You might even get a discount for bulk...LOL.
Bob
Bob Hutson
Old 12-17-2013, 02:07 PM
thanks, ordered 50 from rock auto.
206 637 4071
Old 12-23-2013, 03:31 PM
BoxsterGT's Avatar
Porsche Crest
The ones from Lindsey Racing must be made of "Unobtanium".
Old 03-11-2014, 03:44 AM
83 911 Production Cab #10
JJ 911SC's Avatar
The -01 version is half price but made from Bitcoin...
Who Will Live... Will See
Old 03-11-2014, 04:37 AM
pors1968's Avatar
Same is use for 964 3.6 to plug oil hole near thermostat
Old 03-11-2014, 05:47 AM
