Where are the engine serial #'s located
for a 1965 911? Is it that same number stamped on the rear fan (begins with 901) or is it stamped elsewhere on the case itself. Thanks.
Old 08-25-2002, 02:24 PM
pwd72s's Avatar
Somebody correct me if I'm wrong, but I think it's in the same location on all 911 engines. There is a case upright post...go to 3:00 on your fan surround....look straight down, and you should see the upright post...moulded into the case, like a brace for the fan surround. THe number should be stamped there. If no number, it means a replacement case was used.
Old 08-25-2002, 02:34 PM
