Alignment needed after new Bilsteins??
on 83sc, I'm replacing stock Bego shocks with 4 Bilsteins...do I need to have an alignment afterwards?
Old 08-25-2002, 02:01 PM
Chris Lovell's Avatar
I replaced my Boges with Bilsteins. No alignment needed for me.
CWL
'88 Carrera Cab
Old 08-25-2002, 02:11 PM
thanks Chris...that's good to know, since I plan on installing the shocks after the tires are on and the car aligned.
Old 08-25-2002, 03:06 PM
Switching to Bilsteins caused my ride height to go up about an inch. Had to drop it back down by reindexing rear torsion bars and simply lower the front with the bolt adjustment. All of which requires a realignment.
Do the shocks and struts first then the alignment.
Randy
'87 911 Targa
'17 Macan GTS
Old 08-25-2002, 05:16 PM
jwill911's Avatar
You don't necessarily upset the camber/caster adjustment at the top of the shock tower to replace the struts. But if you replace with a strut/shock that changes the suspension geometry (ride height) at all it will likely chew up your new tires. BTDT wasted a set of front tires in ~5K miles after I put my new Koni adjustables in my `87 without getting an alignment. Don't believe it when someone tells you it won't need an alignment.
jw
Old 08-25-2002, 08:22 PM
Originally posted by Wayne at Pelican Parts
Since you have to remove the top of the shock towers from the car, you will indeed messup your camber settings, and should have them readjusted...
-Wayne
hey, you guys didn't tell me I had to remove the top of the shock towers when I ordered the parts....I was told that the Bilsteins should fit where the Boges were without a problem.
Old 08-25-2002, 08:47 PM
My height also increased a lot -- enough for me to get the ride ht readjusted!!!!
Old 08-25-2002, 10:37 PM
cary's Avatar
I'm with Randy. Mine went up about 1 inch in the back.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 08-26-2002, 04:01 AM
