Alignment needed after new Bilsteins??
on 83sc, I'm replacing stock Bego shocks with 4 Bilsteins...do I need to have an alignment afterwards?
I replaced my Boges with Bilsteins. No alignment needed for me.
CWL '88 Carrera Cab |
thanks Chris...that's good to know, since I plan on installing the shocks after the tires are on and the car aligned.
Switching to Bilsteins caused my ride height to go up about an inch. Had to drop it back down by reindexing rear torsion bars and simply lower the front with the bolt adjustment. All of which requires a realignment.
Do the shocks and struts first then the alignment.
Randy '87 911 Targa '17 Macan GTS |
Author of "101 Projects"
Since you have to remove the top of the shock towers from the car, you will indeed messup your camber settings, and should have them readjusted...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
You don't necessarily upset the camber/caster adjustment at the top of the shock tower to replace the struts. But if you replace with a strut/shock that changes the suspension geometry (ride height) at all it will likely chew up your new tires. BTDT wasted a set of front tires in ~5K miles after I put my new Koni adjustables in my `87 without getting an alignment. Don't believe it when someone tells you it won't need an alignment.
jw |
My height also increased a lot -- enough for me to get the ride ht readjusted!!!!
I'm with Randy. Mine went up about 1 inch in the back.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
