-   -   Another 3.2 Engine rebuild - lots of questions! (http://forums.pelicanparts.com/porsche-911-technical-forum/787204-another-3-2-engine-rebuild-lots-questions.html)
GaryR 12-16-2013 07:08 AM
I just started ripping into my first 3.2, got it from a reputable shop nearby needing a complete rebuild. It looks like it has been stored in a salt mine but was actually running at the track a month or so ago! Anyway, ordered the Bentley 3.2 manual for reference but until that arrives I figured I would liven up Pelican with some nasty engine pictures!
First, the anchor.. errr, engine as picked up -
http://forums.pelicanparts.com/uploa...1387205791.jpg
How are these hose replacements normally handled? DIY, from our host?
http://forums.pelicanparts.com/uploa...1387204029.jpg
And these -
http://forums.pelicanparts.com/uploa...1387206123.jpg
What is this larger thing called, think i'll replace it just for looking nasty.. what does the small sensor do?
http://forums.pelicanparts.com/uploa...1387206193.jpg
Are these lines necessary, small one looks cut, big one plugged?
http://forums.pelicanparts.com/uploa...1387206259.jpg
Need a blockoff plate for this, seems bigger than what my 3.0 had on it... where can I get one?
http://forums.pelicanparts.com/uploa...1387206319.jpg
I'm having Len do all new fuel lines including that tiny J line circled so that part is all good.
Thanks that's it for today! SmileWavy
yelcab1 12-16-2013 07:13 AM
You mention Len so that is a source for all your hoses. Good!
The funny nasty thing is called an Idle Valve.
Look in the used market for a block off plate, or backdate the heat.
GaryR 12-16-2013 07:14 AM
Forgot this, how she sits now, need to get tools for 12mm exhaust nuts and allen nuts, i'm used to dealing with headers!
http://forums.pelicanparts.com/uploa...1387206799.jpg
GaryR 12-16-2013 07:16 AM
Thanks Yelcab, no heat, will have M&K headers as it will be a race motor. I sent Len an email about all the air hoses as I would just as soon send him that one metal-to-rubber breather line for him to crimp a new fitting on when I send my other lines in. I'm going all new SS fuel lines, no point scrimping on safety in a race car! :D
KTL 12-16-2013 08:02 AM
No more carbs Gary? Welcome to the crank it up and go club of Motronic fuel injection!
Those plugged hoses are for the PCV valve (#31). The parts diagram calls it a "recirculating air valve. Just leave them plugged however you wish.
http://forums.pelicanparts.com/uploa...1387208665.jpg
For that missing shroud area where the heater plenum used to be, you can use the old plastic piece by chopping it and fabricate a cover for it. Mine was really crude
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/690554-fan-shroud-blockoff-plate-poor-mans-3-2-version.html
Or there are fiberglass pieces for $70.
Porsche 911 & Carrera Engine Miscellaneous - Page 8
If you get a new idle air control valve, keep the old for a spare. The little "sensor" below it is actually a harness pigtail for the useless TDC sensor that is on top of the engine right over the flywheel. It's a diagnostic sensor that is never used. Just remove it.
The various hoses can be sourced new. Some you can make yourself with basic hose. On the straight sections I used some Aeroquip socketless hose. This hose is very thick and good for vaccuum usage. The crimp clamps are basic Oetiker clamps you can get from McMaster.
The hose that has a 180 degree bend can be had from Pelican. Part no. 999.181.068.41 It is a pre-formed hose that is the perfect replacement.
The short hose beneath the fuel pressure regulator is a must to replace. That sucker is always cracked and a hazard. Len can set you up with that no problem.
The best tool i've found for the exhaust hex nuts is a 13mm universal socket. The integrated kind with the 13mm socket built into the u-joint. Craftsman brand works just fine. For the barrel head nuts, use a fairly long 8mm hex key with the bend cut off. Then insert the key into your 3/8 drive 8mm socket.
I suspect you'll need to replace the DME reference sensors, as they're typically toast by now. Make sure to get the BMW part number that is 1/2 the Porsche price, despite it being the exact same Bosch sensor, just with a bit longer cable on it.
yelcab1 12-16-2013 08:19 AM
For the exhaust nuts on a 3.2L, I have used
1) long 8mm allen socket (I think it is 8mm)
2) Box and open ended 13mm wrench
3) Deep offset 13mm boxed end
and have never needed anything other than those.
GaryR 12-16-2013 08:56 AM
Thanks guys, the info is greatly appreciated and i'm adding the hoses to my project list. Very strange thing is, I have the 13mm U-joint socket but these nuts are 12mm... I shoved a 12mm open end wrench on them to double check. I'm buying a Mapp gas torch and borrowing the 12mm socket and 8mm allen from a friend today so will most likely get them off tonight. If Sears has a long 8mm and 10mm (good for the starter and head nuts) allen I can cut off and weld to a 3/8" socket i'll make my own..
As for the reference sensors, amazingly they were replaced somewhat recently and never-seized before installation so they slid right out. I planned on buying new ones and keeping these as spares also. Is there a BMW part for the CHT? That is rusted in, will have the machine shop remove it when I get the heads done and have them drill out the 12 broken 4mm(?) shroud bolts and replace every stud....
Carbs Kevin? That was waaay back on my RSR project! This engine replaces the 3.0L in my Stock D PCA race car, along with Carrera brakes and regearing, to move me into Stock E!
GaryR 12-16-2013 09:40 AM
Another few questions - I assume I will have to put an oxy sensor into my headers for this to run properly? Any specific one or just use the stock one (cable long enough?)?
The hoses to the IACV apparently are NLA... Just replace with straight hose?
93011066500
93011058902
As is this little tapered rubber check valve sleeve.. have to match something up?
930-207-243-01
r-mm 12-16-2013 10:16 AM
Great project. As you know, I'm around the corner and just wrapping up my 3.2 rebuild.
I was able to get at the trickier exhaust hex nuts but cutting / bending a sacrificial box wrench. maybe get a few at HF? Along with some MAPP and the 6T press, I was able to make an "s" tool. I also bought some low profile wobble sockets but they were almost as hard to use as the modified box wrench setup.
So far as I know there is no alternative to the CHT.
Don't see why you'd use any other oxygen sensor than the one the car came with. Bosch sells them both as "universal" = you wire it and "oem" = has pigtail on it.
Welcome to motronic indeed. In all my years of wrenching I have come to greatly appreciate this vintage of fuel injection. Simple, reliable, tunable, cheap sensors, not that much can go wrong!
GaryR 12-16-2013 12:04 PM
I can go back and look, but what did you do about those hoses that are NLA, especially the tapered ones??
r-mm 12-16-2013 12:05 PM
RESCUE TAPE Self-Fusing Silicone Tape: Amazon.com: Industrial & Scientific
KTL 12-16-2013 12:11 PM
If the hoses to the ICV aren't cracked, i'd just reuse them. Otherwise, see if Len can get some pre-formed hose sections for you if you provide the dimensions to him?
Yep you need to use the O2 sensor if you stick with a typical USA ECU & chip programming. However if you were to have the Euro programming then the ECU/chip is such that the O2 is eliminated.
r-mm 12-16-2013 12:16 PM
Huh, out of curiosity if all things were equal, I wonder what would change in terms of HP, MPG, drivability when going from the O2 fed DME to the non O2 DME? I'm guessing it would not be that easy a comparison in real life since the Euro DME is tuned for higher comp, no cat, maybe other things?
GaryR 12-16-2013 12:20 PM
Thx Kevin.
I think I may be able to match up some hoses here and elsewhere using silicone - HPS 1/2" 13mm 45 Degree Elbow Coupler Silicone Hose 4-Ply Reinforced High Temp black
Will need to get the right ID's and lengths first. I'll check the hoses that are on there but if they are like everything else I will want them replaced. I emailed Len about a complete "kit" for all rubber (except the long J hose and the straight pieces (that are not tapered). If anyone knows the ID's of these it would be a great help, else measure them I will... :D
Mehoff 12-16-2013 12:42 PM
FYI, that ridiculous mess of hoses in your second pic is just the brake vacuum; not utile at all in a race car. Just run a hose from the bottom of the intake to the MC (creates the necessary vacuum), plug the outlet at the back of the TB and you're good to go.
I did this out of necessity at the track (forgot to reinstall when putting the motor back in!), and as it turned out most of the 3.2 guys don't use it either.
911pcars 12-16-2013 12:50 PM
To remove and replace the CHT sensor:
14mm deep socket with a slice down one side to clear the harness. Similar to a socket to R&R an O2 sensor.
Sherwood
KTL 12-16-2013 01:01 PM
I think the only key component of that wacky brake vaccuum assembly is the check valve. PMO has one that should work. So Mehoff is right that you could ditch that whole setup and just run a hose with a check valve in it.
14mm flare nut wrench (like the ones used for brake lines that I never use...) also works good on the CHT sensor.
GaryR 12-16-2013 02:04 PM
CHT Sensor is rusted to the extreme, wire was cut as it will be replaced. I have had it soaking in Aero-Kroil and will give it a little tug after heating the head a bit but if it doesn't go easy i'll just add it to the list for the machine shop.. I've snapped enough bolts already!
r-mm 12-16-2013 02:08 PM
Wouldn't sweat it. Machine shop can handle it. Worse comes to worse, what would stop you from just leaving the old one in there and swapping the heads around since they all have the threaded boss?
GaryR 12-16-2013 02:37 PM
I can use the one off a 78 motor I assume? My old 3.0 is being made ready to swap into a car now and i'm sure I can have the one off the junk motor it's replacing.
slimlynn1 12-16-2013 02:54 PM
Check with your chip maker to see if the O2 sensor will even be used.
GaryR 12-16-2013 03:22 PM
Will do "Slim"! :D
GaryR 12-17-2013 10:20 AM
After getting the right tools and a Map gas torch I gave a shot to the exhaust bolts that seem to have remained untouched since 1987 (in a car driven in Northeast winters it seems).
http://forums.pelicanparts.com/uploa...1387304116.jpg
Got two off before finding one Allen with the center rusted out and the next 12mm nut with not enough hex left for a wrench to grab.. Next step is a combination of Plasma Torch, Sawzall, and die grinder! Boy is my machine shop going to love me when I hand them these heads and cam towers! 12 snapped shroud and tin 4mm bolts to drill/tap, all 24 studs to replace! Reminds me of working on my rotted out old VW's when I was a kid!
BTW, what's the point of a MAP gas torch over propane? For this work you need oxy-acetelyne, Map is a joke, $60 tossed away... though the little holster and 5' hose is nice for the next time I have to solder a pipe!
peppy 12-17-2013 10:42 AM
Map is hotter than the propane.
I too had to cut all of my exhaust studs off.
I the engine yoke secure in the stand?
Good luck.
GaryR 12-17-2013 10:47 AM
Good luck.
Yeah, the sleeve is in there and its pinned (in the back). Someday i'll have another sleeve made up as I seem to have an engine on this every year now.... :(
911pcars 12-17-2013 12:03 PM
Did you apply Kroil or equiv. between applications of heat? Heat expansion allows the lube to dissolve/loosen corrosion between the threads and other petrified parts. Of course, this presumes the parts haven't morphed on a molecular level (or something like that).
After the barrel nuts have lost their shape, cut some strategic slots in the internal hex area with a Dremel tool or equiv., then use a long slotted screwdriver/pry bar to apply torque to the fastener. Wait until parts have cooled somewhat as heated metal is soft. Sometimes they come out without the stud snapping. Sometimes they snap. Sometimes the stud will back out of the head (good).
http://forums.pelicanparts.com/uploa...1387310386.jpg
Sherwood
GaryR 12-17-2013 05:15 PM
Sherwood
Yes, been soaking in Aero-Kroil for q week... Rather than try and deal with these from obtuse angles I took my trusty Sawsall and new steel blades and took the heat exchangers off the Marie Antoinette way! I burned through all the blades I had (Stuff is HARD!) and have one last pipe to cut and then I have open access, or can wait and just hand the heads over to the machine shop to deal with, flanges still attached. Will buy another pack of blades tomorrow, finish up tomorrow night, then work on the issue like a gentleman with full open access.
That will end my dealings with rust on this engine (everything else is ok), for now and forever as i'm the king of Never-Seize!
:D
GaryR 12-20-2013 09:23 AM
Any reason to use Raceware vs. ARP Rod bolts? I know stock is a no-no, especially in a race motor, but there is a $150.00 difference between the two brands!
911pcars 12-20-2013 10:11 AM
Some say you get what you pay for. However, there are several messages in this statement.
Sherwood
GaryR 12-20-2013 10:19 AM
Checked, my shop uses ARP.. and so will I!
KTL 12-20-2013 10:27 AM
ARP all the way. They have a very good track record, literally, in these engines.
GaryR 12-20-2013 10:32 AM
Thanks for the reinforcement Kevin, I have plenty of other places to spend that $150!
:rolleyes:
GaryR 12-21-2013 04:20 PM
Decapitated heat exchangers..
http://forums.pelicanparts.com/uploa...1387671564.jpg
Note the 1/2 tube of black RTV someone thought was a good idea to use on the oil return tube to fix a leak...
jager911 12-21-2013 07:31 PM
On the earlier O2 sensor question, I ran my stock 3.2/stock chip for about 10 years with O2 sensor disconnected, then switched to custom chip last year from Steve Wong to match headers/open pipes. According to Steve, for track use at mostly WOT, the O2 sensor won't do anything, needed more for street use, warm-up, fuel economy, low emissions etc. He recommended I leave it disconnected and my car is still streetable.
BGCarrera32 12-21-2013 07:50 PM
:rolleyes:
Heed the man's advice...he knows what he's doing. Now if I could just finish his parts, but that's another story...
I used ARP bolts as well in my 3.2 to 3.4 conversion. I also suggest investing in ARP's dial indicator equipped tool that measures bolt stretch. They go together such that you measure the stretch of the bolt to indicate the correct installation torque. You can do it with a dial caliper or mic but its a pain.
O2 sensors in 3.2 Carreras with stock DMEs operate as a fuel trim device. If you run without it you are using what is called "open loop" and the engine is running on its base fuel and timing map. Safe but less fuel efficiency.
GaryR 12-22-2013 06:34 AM
Steve Wong wrote to me also, it's another $125 I won't spend, this rebuild will practically be free!
GaryR 12-22-2013 08:09 AM
Anyone know if the Beck Arnley Alternator thread size and pitch are the same as stock? I noticed the threads were buggered up when I took it apart. I believe the Marchal is 17mm x 1.5.. I need to get a die and chase these threads, want to be sure it is the correct size. They are flattened on the other side also, worse than what the picture shows.
As one can never have too many tools I ordered a 17mm x 1.0, 1.25, and 1.5 dies to add to my box... hope it's not 16mm (or not metric!). I would use the nut to match up a bolt but its buggered also.
:D
http://forums.pelicanparts.com/uploa...1387728581.jpg
http://forums.pelicanparts.com/uploa...1387728592.jpg
GaryR 12-23-2013 05:43 AM
Ok, how about this - I don't see it in the PET and I know it's an odd ball size so does anyone know the part number for the sealing washers for this end of the tensioner feed? It's the big end on the cam tower..
http://forums.pelicanparts.com/uploa...1387806228.jpg
r-mm 12-23-2013 05:56 AM
Gary are you not buying a gasket kit? I got mine as part of the kit...
Flat6pac 12-23-2013 06:00 AM
Nothing says you need the heat boxes out of the way at this point of disassembly.
I have pulled the heads from the engine, removed the rockers, cams, and cam carriers which then makes the nuts more easily worked on to remove the heads. But I have had the inserts in the Carrera heads hold on after nuts are removed, then you need an air chisel.
Bruce
