Send a message via Yahoo to mobius911
I have MFI and have many of the problems you describe. I haven't had any for a while so I'm feeling pretty good about things now. But I know how you're feeling.
Electrical issues I have had:
-CDI dead, or works intermittently (like starts mis-firing when hot)
-Points close up, probably because I didn't tighten the screw enough
-Coil died
Good luck. This too shall pass!
Jeff Jensen
1973 911
Old 12-19-2013, 09:14 PM
CDI was bad so the seller repaired at no cost. Also got the 69 pump repaired by Fairchild.
Then found pinholes in rubber fuel lines that connect hard lines in front of gearbox area. Fixed those and off to the races.
Just some fine adjustment to CO levels and we will be golden.
Thanks,
Matthew
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 05-03-2014, 06:22 PM
Chain fence eating turbo
MFI to EFI
Old 05-03-2014, 08:11 PM
-Coil died
put a Pertronix setup in place of the points! Easy and never worry about points again. PUt is a new CDI I like Daytona-Sensors CD-1 kit.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-03-2014, 08:50 PM
TR TR is offline
TR's Avatar
mfi probs
So you're going to keep the car?
Old 05-04-2014, 01:45 AM
