non-whiner
Fitting my IROC wing
So right up front I will admit to liking things to fit properly. A friend of mine always says, "it's race ready". What he means is the fit is a 20 footer. That just doesn't work for me.
Today I started fitting my IROC wing. It's a well made piece, but has a few fitment challenges. First off, notice the edges of the engine compartment opening are straight: ![]() But not the wing, in fact it is too wide to fit in the opening about 1/3 of the way down: ![]() And there is a corner missing on the lower left side: ![]() The actual problem is that the area under the straight edge need to be removed (where I've ground away the gel coat): ![]() ![]() Cut up some strips of fg cloth and bond them in place: ![]() ![]() ![]() Also, need to fill in the edge, but I don't want the repair to snap off after paint, so drill a few small holes and bond in some pins followed by long strand fg filler: ![]() ![]() Thursday I'll grind and fit it and then sand the entire wing and start filling pin holes and imperfections. So many projects, so little time! Last edited by mreid; 12-25-2013 at 08:12 AM.. |
MBruns for President
From another person with that same mindset - Thank You for making it fit correctly
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Why are fiberglass panels made with such lousy tolerances? Quite a few threads here with some heavy modifications done in order for them to fit right.
1982 911 Targa, 3.0L ROW with Webers |
non-whiner
I knew you would understand, Jeremy!
"Too much is just enough." |
