porsher
aston@ultrasw.c's Avatar
3.6 conversion pics
I am gathering parts to install a 3.6 into my 86 911.
The engine is a 95, non-varioram. I also have a shortened G50 on the way.
I am looking for pics of the conversion to help guide me along.
Things like the engine installed, the engine all built and ready to install, trans cross member, pedal box etc...
Show us how you solved all the various little issues that crop up.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-06-2013, 08:27 AM
RETIRED
Joe Bob's Avatar
InstantG's Home Page
Some pics here....
2012 ML350 3.0 Turbo Diesel
Old 02-06-2013, 11:27 AM
Deadeye's Avatar
I'm in the middle of this operation now and will get a few photos that might help you out and post here.
Old 02-06-2013, 02:51 PM
dshepp806's Avatar
Nice link, Joe Bob,..thanks!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-06-2013, 03:59 PM
RETIRED
Joe Bob's Avatar
Bought from him....not the most sunny disposition but he knows his stuff.....
Old 02-06-2013, 04:00 PM
Certified User
billjam's Avatar
This conversion has been stalled for quite a few months while other projects took priority, but I am actually considering dropping the 3.2 this weekend and taking it the next step.
I haven't necessarily done everything by the easiest or most direct route 'coz I just love tinkering and trying different things, but there might be a few areas of common interest.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 02-06-2013, 09:18 PM
porsher
I'll get things started.
Here's how I reinforced the engine cross member to take the extra load.
79 928 Race Car
Old 02-08-2013, 05:05 PM
porsher
Here's some pics from this mornings activities.
I had the engine cradle sand blasted and had just started squirting it with primer when I noticed a crack.
So I drilled and ground it out and welded it shut.
Then I decided to add some reinforcing
That should do it.
79 928 Race Car
Old 02-09-2013, 03:09 PM
RETIRED
Joe Bob's Avatar
Would suggest a WEVO carrier bearing upgrade for those using a 915 trans. G50 has one already.
Old 02-09-2013, 03:15 PM
$ Short's Avatar
Chris. Do you think you'll have this motor installed and ready for the Indy DE?
Old 02-10-2013, 06:24 AM
porsher
Not in April, but likely in November!
79 928 Race Car
Old 02-10-2013, 08:35 AM
non-whiner
mreid's Avatar
I solved the issues of putting a 1995 3.6 in my 1984 911 with my check book, so I might not be able to offer a lot of help. I'm installing this today:
Old 02-10-2013, 08:45 AM
nice
Old 02-10-2013, 10:11 AM
Who build that nice engine cross member?
I just bought a 88 Coupe with 993 engine.
My cross member looks a little bended, probably the G50 was not shortened...
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 10-31-2013, 12:16 PM
non-whiner
mreid's Avatar
Rennspeed, here on Pelican.
"Too much is just enough."
Old 10-31-2013, 03:22 PM
Crossmember
Thanks for the Info!
Now I might find some time working on the car.
My crossmember is bended like a banana (approx 1inch) and I am thinking to change this.
The main reason, I have a lot of engine/gearbox noise in the car.
Its getting more when the engine gets warm.
I think that there might be some tension on engine and gearbox mounts.
Wouldnt`t it be better to build a engine crossmember wich fits to the mounting points, instead of bending the original one?
Further I saw that there are spacers used between the crossmember and the engine mounts on some conversions.
Whats the reason to lower the engine?
thanks
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 01-10-2014, 01:12 AM
tshebib's Avatar
Here you go
Finally registered with Pelican- Introduction
I used Instant-G with great results and support.
BTW, that's only the beginning. After that, you'll be looking for transmission upgrades, brake upgrades, suspension upgrades and of course then comes the roll bar, harnesses and seats.......... Lovin' every minute of it!!
Old 01-10-2014, 05:59 AM
redturbo911's Avatar
Falk930 can you post some pics for us? Thank you.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 01-10-2014, 06:10 AM
One of the problems you encounter is spacing. The 3.6 w/ G50 (even a shortened one) is a bit longer than the original package. Most just bend the rear engine mount a bit and call it a day. Some clearance the torsion tube, and use a modified 915 transmission mount to move the new package forward. Patrick Motorsports makes a transmission mount w/ slotted bolt holes so you have a range to mount the transmission. If you want to keep your torsion bars (I would for a street car) it gets pretty tight space wise. If you go to coil overs, hack away, but be aware that you will have to modify your shock towers to accommodate the extra load. Why not keep your 915 transmission, it would simplify things, and I think for a street driven car they are up to the task.
Old 01-10-2014, 08:30 AM
I have a 1974 With 3,6 anf G64, also had to bend the rear crossmember approx an inch, this make correct fit to rubber around the engine towards body...also: every millimeter forward is good for car handling!
Old 01-10-2014, 09:38 AM
