Stuck here, can't figure the part (window regulator issue)
Hi Pelicans.
I finally wrestled the regulator out of the door on my '83SC Targa. I wanted it out b/c I found this when I was poking around at the bottom of the door, and I found the pin that connects to the end of the regulator spring, which I refer to as the "shorn-off pin": http://forums.pelicanparts.com/uploa...1389149019.jpg I thought I ordered the correct pin to replace it, but it seems like not: http://forums.pelicanparts.com/uploa...1389148845.jpg The pin below the spring seems like a replacement for the pin at the center of the spring. I can't see it fitting in the slot to the left of the shorn-off pin, which I think is what I am going for here. Now, there are many threads to help with regulators, and believe me I consulted them, but still managed to order the wrong part. See http://forums.pelicanparts.com/porsche-911-technical-forum/233103-part-found-inside-driver-door-what.html and http://forums.pelicanparts.com/porsche-911-technical-forum/639895-window-regulator.html and especially http://forums.pelicanparts.com/porsche-911-technical-forum/516041-window-regulator-pivot-pin.html I've consulted the PET, but no help there. Can anyone direct me to the exact part number? Thanks, Pelicans! |
You ordered PEL 910393 which as you say is for the centre of the spring. You wanted 910394 which is for the other end.
Thanks very much. Is there a perpendicular/parallel difference? 24mm v. 26mm? 910394 is perpendicular, 26mm...
| All times are GMT -8. The time now is 05:28 AM. |
