Chain fence eating turbo
Sal, I used your numbers again and it started and it didn't die. Although a little rough, it didn't die. What I think is happening is what Lapkritis posted earlier.
Simply, at idle, my pulse widths are too short due to 3 injections a revolution of crank vs 1 per rev making my already big injectors have to fire a third of the pulse width it could be doing causing instability of injections (1.0ms vs 3.0ms).
Once at 1 injection/revolution, it should smooth out. But, retuning has been a bear!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-19-2014, 08:18 AM
scarceller's Avatar
Most hi-imp injectors have dead times of .6 to .9ms and you can not make pulse widths any shorter than the dead time. As a rule of thumb you want your minimum pulse width to be deadTime * 25% so for a dead time of .7ms * 1.25 = .875ms
You can not expect an injector to accurately meter fuel below or near it's dead time. The factory Motronic has a minimum injection pulse time built in and it will NEVER allow a commanded pulse width below this built in threshold. In the 89 stock chip this min inj pulse width is set at .9ms and this is with lo-imp injectors that have dead time of .45ms. Here you see that minInjPulse of .9ms is 2X the injectors dead time. This setup fires injectors 1 time per crank rev or 2 times per stroke.
Bottom line is try to keep minInjTimes at least 25% longer than dead time.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 01-20-2014, 06:41 AM
