72 911 fuse order
What is the proper order of the fuses in a 72 911? I have looked at a couple cars, and they seem to be different. I mean order as far as amps (color) of the fuses. I have a bare fuse box with no fuses in it. Thanks all.
From the 1972 owners manual:
upper box or box one in the luggage compartment; (10 fuse positions) top to bottom, rating in amps: 5,16,25,16,16,25,25,16,5,5 lower box or box two in the luggage compartment; (8 fuse positions) top to bottom, rating in amps: 8,8,8,8,5,5,5,16 box three in the engine compartment on the electrical chassis on the driver's side of the compartment under the plastic cover - if the cover still exists, (3 fuse positions) top to bottom,rating in amps: 5,8,25 5 amp fuses are yellow 8 amp fuses are white 16 amp fuses are red 25 amp fuses are blue Cheers, Jim Last edited by Jim Sims; 09-25-2003 at 10:00 PM.. |
Administrator
Any chance of any 72 owners being able to carefully remove, and scan, the paper insert with the listings on it? Or, if that's not possible, to snap a picture... or type out the list?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
PRO Motorsports
Mine are still intact, Jack. Unfortunately, it only lists what the fuse is for, not the amp rating.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Yup, that was the problem. Every car I looked at had different amp fuses in different places. I needed a good "unmolested" car as an example. Thanks guys!!
Jack, next time you're near "scruffy",bring your camera! Great Info, Jim...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Administrator
Yeah, my thinking is to take a copy of the paper inserts, scan it, and then add the amp numbers.
Hi Guys, that's GeorgeK on Nick's computer. He is over my shoulder ordering me around, so here is a scan that may help you all.
![]() GeorgeK/Nick Moss |
Here's a pic from my 1972 fuse boxes:
1972 Porsche 911 coupe 2016 McLaren 570S 2016 Cayman GTS 2016 Land Rover LR4 HSE 2013 Mini Cooper S |
Do a search on "fused box labels" with Pope as the author. As I remember, the 70/71/72/73 fuse box label files are available there. Print on heavy stock paper, and laminate for durability. Mine turned out great.
Al |
Make that fuse, not fused.
You do know you are answering a post from 2003.
The car is still the same. Plenty of people like me search old threads for valuable info like this.
HOW MANY PELICANS DOES IT TAKE TO CHANGE A LIGHT BULB? Quote:
Which fuse supplies the light bulb, Harry?
Great post ...... And so so funny because it is so so accurate. ![]() Mick |
