Bill Verburg's Avatar
The 993RS big red kit from Racetech sure looks cool though and they are great for a track car
my car
same brakes on my other car
Bill Verburg
Old 01-26-2014, 08:50 AM
Originally Posted by Bill Verburg View Post
Unless you are tracking the car yes, stock Carrera are going to be fine, the bigger brakes mostly give you thermal capacity that is never used on the street, you do get more brake torque but since stock brakes can lock the wheels and it's the tires that are stopping the car it's not really useable w/o all the other track car mods
Bill, I will be tracking and autocrossing the car.
Old 01-26-2014, 08:55 AM
For A/X I'd want Carrera maybe even w/o the p/v to get the rear bias to help rotate the car
for bi track use heat is always an issue w/ Carrera brakes but lots of people manage to deal w/ it
what you have, IMO, is dangerous
Bill Verburg
Old 01-26-2014, 08:58 AM
Sounds like we are on the same page here, and that maybe backdating to the original brakes will yield the best result. I would need new rotors, what would you recommend in that department?
Old 01-26-2014, 09:11 AM
For 3.2 Carrera rotors, stock or Zimmerman coated
Bill Verburg
Old 01-26-2014, 12:01 PM
Diss Member
Quicksilver's Avatar
You should never use a p/v on the front
So people aren't confused (or chose to ignore his advice) I want to layout WHY you never put a proportioning valve in the front brake circuit of a car.
A proportioning valve works by reducing the pressure that is downstream of the valve. It can be by a set percentage of pressure, a set psi of pressure, or a combination of the two. The important part is that it is reducing the pressure and one of the ramifications is that the pressure to the caliper can not be released without releasing the upstream pressure to the point where it is less then the downstream pressure.
It is very important that you be able to modulate your front brakes. They do most of the stopping. As an easy example let's say you have front brakes that lock up with 400 PSI of brake pressure and you have a proportioning valve that cuts off 20% of the line pressure.
You start braking hard and lock the fronts by applying 400 PSI to the calipers. Normally you would just reduce the pedal force by a slight amount but with a proportioning valve the upstream line feeding the fronts was at 500 PSI and until it is reduced to 400 PSI none of the pressure to the fronts will be released. And when it does start releasing the release will be 20% less then you would expect from the pedal feel.
After you have released the pressure and you want to increase the pressure you first have to build the upstream pressure by 20% before you get any increase in pressure to the caliper. In other words there isn't any real modulation of the front brakes.
A proportioning valve is an obvious kludge to balance the brakes. Most cars have a much higher percentage of weight on front end. Add that to the weight transfer to the front end and it usually works out to 70% or more of the brakes are on the front. This means that such a small percentage of the braking is done by the rears that the bad characteristics of a rear proportioning valve isn't noticeable.
One of the really nice things about the brakes on an early 911 is there is no proportioning valve. This gives you wonderful brake modulation and great feel right out of the box. Messing with that balance really takes a lot of thought. (and a calculator!)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-26-2014, 04:23 PM
Walt Fricke's Avatar
Westy
Use the search function here with something like "Carrera brake bias valve." You should find some pictures, and a graph. What this amazingly small unit does is allow the pressure your foot produces coming out of the master cylinder to climb in a straight line on a graph as if no valve were there, so front and rear calipers get the same pressure, up to a set pressure. After that, the front pressure climbs just as it did before, but the line to the rear flattens. I don't recall if it is just limited and never gets higher, or if it just rises at a lesser rate. There is an orfice in this valve, and it can be changed. I believe Porsche used different orfices on some later cars, so guys with the stock setup can play around a little.
If I understand Wayne's post, it sounds like this approach (and the aftermarket bias valves) works for the rear, because you use it to prevent rear lockup at threshold braking. Which means you never have to modulate your braking to avoid lockup in the rear.
The proper race car setup involves an adjustable bias bar on a dual master cylinder system, but you don't want to go there.
In fact, the advice you have been given about reverting to stock (at least for now) is very good:
For autocross, stock unmolested brakes are just fine.
For beginner track use, the same is true. Stock is fine. As you get quicker, you would switch to a better brake fluid - say one with a 600 degree F dry boiling temperature, or even better. As you get quicker yet, you remove the brake dust shields, duct air to the front brakes and install blockoff plates so the air can't just blow out the spokes of the hub. If you do this right, you can race this way. PCA Club Racing Stock class rules require the stock brakes, and guys do just fine in the 3.2s in the brake department as long as they pay careful attention to cooling and really good fluid.
Now if you have pumped this engine up to 320 HP, that's a different matter. More speed = more heat when you have to brake.
Old 01-26-2014, 05:44 PM
creaturecat's Avatar
Bill has never "steered" me in the wrong direction.
Old 01-26-2014, 05:48 PM
I'm just wondering if that is the ultimate solution here? While I can remove the current set up and revert to stock, if ultimately I will need to upgrade perhaps just using a dual master now would set things right.
I will be calling RaceTech tomorrow to see what they have to say.
As always, I really appreciate all the wisdom shared here.
Old 01-26-2014, 07:12 PM
Unless I miss my guess, you'll lose your power braking (vacuum boost) with a dual MC, although with the MC up in the trunk it has to be easier to install than on earlier cars with the MC down by the steering. But perhaps there is some other kind of power brake assist which will boost a dual MC and bias bar setup. All of which may be more work and expense than just going back to stock?
Old 01-26-2014, 07:41 PM
Porsche fanatic
jager911's Avatar
As an another data point, I installed '88 Carrera brakes in my '74 15 years ago and had to install a stock bias valve in the rear line. After many years of track use, I upgraded to 993TT front/rear with the proper 23mm MC. I then had to remove the rear bias valve and my brakes work just fine under track use. The front pads wear slightly more than the rears but the rears are definitely working. I agree, the first thing to try is to remove the stock bias valve, if it's still there.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 01-27-2014, 03:55 AM
The dual master setup provides the ultimate in adjustability
it adjusts 2 ways
1) bias bar for small changes
2) different m/c for the front and rear circuits so that each can be sized as needed
Bill Verburg
Old 01-27-2014, 04:28 AM
Oh and for all the ones I've seen for 911 installation you do lose the vacuum assist
Bill Verburg
Old 01-27-2014, 04:31 AM
Update,
So I called RaceTech today and they were very interested in being helpful. I explained the situation, and gave them all the part numbers.
The Front Calipers are as Bill suggested, F40 Calipers AKA "B" callipers as noted by the B in the part number. Originally designed for use on the Ferrari F40.
The B calliper comes in both small and large bore, 3640mm is the application in this case, and is considered the small bore.
The rear Kit is known as the Mini Jag, or "C" calliper and originally designed for Jaguar.
The C calliper for the rear has a 2840mm bore.
I found the OEM bias valve in place under the hood as some may have suspected.
We are assuming at this point that the pads are the standard issue Ferrodo front and rear.
According to RaceTech they sold about 100 of these kits and never had one complaint of this type. That being said they were happy to look into it further. We agreed that the first thing would be to check and confirm that I did receive the small bore callipers in my kit as they are easily mixed up. I took some pictures and sent them off so they could compare.
A few hours later, I had a call back from race tech looking for some more detailed info about whats been happening, and a more detailed description of my car and its modifications. I was really surprised, and delighted by this level of concern on their behalf. The tech took all of my info and will be speaking with the owner of the company about it who is reportedly very experienced with Porsche/Brembo braking and has been personally racing for many years.
Old 01-27-2014, 06:50 PM
I'm very happy to see they are giving you good customer service. Seems to be a huge exception to the rule these days, good for them.
Question for Bill (and some of these other guys who know this set up well), are you guys thinking that this just too much of a mis-match to fix with changing pads, aggressive in the rear, and sort of minimally aggressive in the front?
Obviously, correction from the supplier w/o too much $ outlay would be best but, when I think of the cost of some of the changes that have been mentioned, it sounds SERIOUS!
I too have massive Brembos installed by PO w/o much info but, my brake balance seems very good. One thing I've noticed is that you really do need self control when you have this much brake. If someone's used to abs or maybe just having a big v8 sitting right over the front wheels, there's no doubt it's a serious adjustment mentally. Looking forward to resolution!
cd
'82 Targa
Old 01-27-2014, 07:35 PM
Diss Member
The one way to do it while retaining the power steering is use the Tilton 72-610 mount. I thought about going this way back when I was upgrading my system. It would require that you add a bellcrank so you could mount it 90° to the side of the booster.
In my case I ultimately really wanted to lose the power booster as it eats some of the sensitivity you get from the dual master setup. I ended up putting in the Smart Racing setup and have been loving it for more then 10 years.
Old 01-28-2014, 02:34 AM
Update,
Ok that changes things a lot as I said there were several different versions of that setup
I suspect that the rear bore is 28/30, I have never heard of a 28/40, please double check that.
assuming 40/36 front and 28/30 rear on 322mm rotors torque@70bar is is 2067nm 1241nm and bias is 1.666
that is much closer to where you want to be, you definitely need to remove the p/v as that cuts in at 33bar and makes the front bias much higher from that point up.
you can further trim bias w/ pad selection
for example Pagid RS 19 fronts and 29 or 14 rear
or 29 front 14 rear
Bill Verburg
Old 01-28-2014, 04:17 AM
or 29 front 14 rear
Hi Bill,
My mistake, just checked my notes and yes its 28/30 for the rears. With regards to pad selection, which of your recommendations could be considered street able if any?
For the p/v removal, would you suggest a simple union, or something adjustable?
Cheers!
Old 01-28-2014, 09:37 AM
Hi Bill,
Cheers!
well I use Pagid RS29 f/r on the 993 and don't swp them out for street use, I have no issues w/ them, but I don't drive in temps below 40F
On the C3 I have used Pagid sort blue, but that's not really a track pad
if native bias is ~ 1.6 then I think that 19 front and 29 rear would move a little bias to the rear w/ issue.
I've found that the trick to living w/ track pads on the street is to keep them clean and never put them away wet
Bill Verburg
Old 01-28-2014, 09:52 AM
The forum strikes again, or at least BV.
Wayne - that Tilton part looks like it is for a non-powered dual MC setup. Wouldn't the big pie plate vacuum boosters bump into each other if you tried to mount two MCs more or less side by side? Mounting a dual MC on an SC or 3.2 is pretty easy, what with the adapters out there. But power seems harder with the older vacuum systems.
I agree with you that power brakes can be suboptimal. On my SC, to which I added the stock power brake setup several years ago (long story) no longer allows me to just kiss the brakes where a fast sweeper requires something (or the driver does for confidence), but not the loss of much speed. I always seem to get a bit more than I want in those situations.
Old 01-28-2014, 04:40 PM
