toddu's Avatar
Rear end clunk
Have a noise in my rear end that is drving me nuts. It's on the drivers side, suspension related I think, but can't zero in on it. If I push down on the bumper I don't necessarily hear it. I pick up on the bumper, drivers side a bit I can hear the "clunk" noise pretty regularly. If I simply bounce the bumper a bit, I don't always hear it, but sometimes I will. So it is slightly random.
I do have polybronze bushing in the rear. I wouldn't think they would clunk. I also have an adjustable sway, which I haven't tried to disconnect to see if that might be it (maybe some binding or something?). I slightly suspect my CV joints are getting close to a rebuild, but wouldn't think that would clunk moving the car up and down. The torsion bars have also been upgraded. Car has been aligned and corner balanced.
Todd
'81 SC
Old 04-22-2012, 09:08 AM
docrodg's Avatar
Try having a friend move it while you look for the noise source. I you are lucky just a bolt that needs snugged up.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-22-2012, 09:37 AM
Member 911 Anonymous
DRACO A5OG's Avatar
If you can repeat the clunk, while standing, then it is most likely suspension related, check the sway bar mounts, they tend to snap over time and severe stress.
Also check the torsion bar plate cover end cap, see if they are touching.
'85 Carrera Targa
PCA/POC
Old 04-22-2012, 09:41 AM
Also check shock mounts.
1986 3.2 Carrera
Old 04-22-2012, 10:02 AM
Have same issue.....Fix?
Old 04-27-2012, 08:28 AM
River Rat
Dave 86 930 Fl's Avatar
Pick up an automotive stethoscope ($10) and you will find your problem.
Old 04-27-2012, 01:47 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
check motor and trans mount too.
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 04-27-2012, 03:48 PM
RETIRED
Joe Bob's Avatar
Clunking in a turn is usually the CV, clunking on accel/decel or a bump is likely the sway bar mount.
2012 ML350 3.0 Turbo Diesel
Old 04-27-2012, 06:01 PM
spray some synthetic oil on the rear swaybar rubber bushing. Most likely these. Also make sure the adjustable swaybar hardware is tight.
Old 04-27-2012, 06:10 PM
Super_Dave_D's Avatar
My 88 was doing the same thing. Droplinks
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 04-27-2012, 06:41 PM
toddu's Avatar
Mine seems to be only if I jerk up on the rear bumper. I can for the most part bounce on the rear bumper (doesn't move much though) without noise. Was thinking of disconnecting drop links and checking it out. Maybe tomorrow.
I'm sure it's nothing to be concerned about, but now it's one of those things that just drive you nuts, you know how it is.
Todd
'81 SC
Old 04-27-2012, 07:00 PM
Send a message via Skype™ to KNIGHTRACE
Sounds like shock
Old 04-27-2012, 10:16 PM
Could someone clarify what exactly to look for in rear shock mounts? Is this something I check inside the engine bay or from below? I have a really annoying faint clunk going over smallish bumps and I do not have a sway bar on the rear at this point (bracket to be replaced).
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-29-2014, 08:32 AM
theiceman's Avatar
Make sure rear sway bar brackets haven't broken away from the body.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 01-29-2014, 08:56 AM
Shhhh... Uhhh
Creve's Avatar
[QUOTE=DRACO A5OG;6703567]If you can repeat the clunk, while standing, then it is most likely suspension related, check the sway bar mounts, they tend to snap over time and severe stress.[QUOTE]
+1 This is exactly what happened to me and the intermittent sound you describe was the same.
"Dyin' ain't much of a livin' boy."
- Outlaw Josey Wales
Old 01-29-2014, 09:27 AM
Could be wheel bearing.
Old 01-29-2014, 11:31 AM
Flojo's Avatar
no. they grind and roar when driving, no "clunking"
these were real "clunkers"
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-29-2014, 11:37 AM
For the record, my polybronze bushings clunked up until the point I replaced them with Neatrix... they've been quiet ever since :-)
But I second checking the rear sway bar mount, they rip away from the body very easily and it should be the first thing to check.
Chuck.H
'89 TurboLookTarga, 372k miles
Old 01-29-2014, 12:48 PM
