jibmaster1's Avatar
Should I crack the fuel line when cranking after reinstalling engine before start up?
Maybe the one supplies the fuel rail? I just did a small rehab on my 3.2L and am almost ready to start it again. Thanks.
Old 01-30-2014, 07:14 AM
What is your reason?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-30-2014, 07:26 AM
jibmaster1's Avatar
Maybe cause an air lock in the fuel? So no worries then?
I just wanted to be sure as it's my first drop and reinstall of this car/motor. I'm more in love now then before lol!
Old 01-30-2014, 07:32 AM
There is not a need to crack the fuel line unless you have something very specific in mind.
Check for indication of oil pressure during cranking
Check for leaks
Fire it up and see oil pressure jump immediately
The 3.2L engine is an easier one to start up. You get the timing right it fires. You get it wrong, it does not. No middle ground.
Old 01-30-2014, 07:54 AM
I never do - but you may want to jumper the fuel pump fuse to run the fuel pump for a few seconds to prime the system and minimize cranking while waiting for fuel pressure. This is what I do...
Chuck.H
'89 TurboLookTarga, 372k miles
Old 01-30-2014, 07:55 AM
Diss Member
Quicksilver's Avatar
Just start it. Any air will just go out the injectors or the pressure regulator's return line.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-30-2014, 07:56 AM
jmills's Avatar
I'm in the same boat as I hope to fire up the motor soon after my first engine drop. Could you not just cycle the key on and off a couple of times to prime the fuel system instead of jumpering the fuel pump relay? I also replaced the fuel filter, so I imagine it make take it a little while to prime the system.
Joe
1984 Targa
2006 997 S
2005 Mazdaspeed Miata (track toy)
Old 01-30-2014, 11:04 AM
jibmaster1's Avatar
You guys were ALL right! Fired up within 5 seconds and purred perfectly! Just like it left the factory 29 years ago
Old 01-30-2014, 12:29 PM
French Import
zippy_gg's Avatar
Kudos! You did something right!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-30-2014, 12:33 PM
jmills's Avatar
Congrats!!!
Joe
1984 Targa
2006 997 S
Old 01-30-2014, 12:46 PM
