LinkBack | Thread Tools |
Should I crack the fuel line when cranking after reinstalling engine before start up?
Maybe the one supplies the fuel rail? I just did a small rehab on my 3.2L and am almost ready to start it again. Thanks.
What is your reason?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Maybe cause an air lock in the fuel? So no worries then?
I just wanted to be sure as it's my first drop and reinstall of this car/motor. I'm more in love now then before lol!
There is not a need to crack the fuel line unless you have something very specific in mind.
Check for indication of oil pressure during cranking Check for leaks Fire it up and see oil pressure jump immediately The 3.2L engine is an easier one to start up. You get the timing right it fires. You get it wrong, it does not. No middle ground.
I never do - but you may want to jumper the fuel pump fuse to run the fuel pump for a few seconds to prime the system and minimize cranking while waiting for fuel pressure. This is what I do...
Chuck.H '89 TurboLookTarga, 372k miles |
Diss Member
Just start it. Any air will just go out the injectors or the pressure regulator's return line.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I'm in the same boat as I hope to fire up the motor soon after my first engine drop. Could you not just cycle the key on and off a couple of times to prime the fuel system instead of jumpering the fuel pump relay? I also replaced the fuel filter, so I imagine it make take it a little while to prime the system.
Joe 1984 Targa 2006 997 S 2005 Mazdaspeed Miata (track toy) |
You guys were ALL right! Fired up within 5 seconds and purred perfectly! Just like it left the factory 29 years ago
French Import
Kudos! You did something right!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Congrats!!!
