AutoBahned
Bruce Anderson and others are (or I should say were as he passed away) basing his advice NOT on anecdotes, but on long experience with large samples of engines.
This would be akin to clinical experience as a medical analogy. Anyone interested can easily read back thru old copies of UpFixin' |
-Andy
72 Carrera RS replica, Spec 911 racer Last edited by Eagledriver; 02-02-2014 at 11:56 AM.. Reason: spelling |
Taking it apart is easy
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Here's an anecdote. I have a rat turd (literally) 1975 2.7 motor that I bought as a core. Never been rebuilt. I popped it in my 73 just to see if I could get it running? It pulls nearly as well as the 3.0 I just pulled out of the car. Doesn't even leak! I truly believe the issues with these motors have much much more to do with temperature control than anything else. I'm going to leave this motor in until I get time/money together to build the original 2.4. I am sure I got lucky but my point is there are still some original 2.7 motors out there that haven't pulled the studs out. I will be running a front cooler and webers tuned slightly rich. I'm curios to see how long it lasts.
70T 2.7RS spec. 68L coupe |
Functionista
According to the build date on my car the OE studs and corresponding holes turn 40 this month.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Functionista
What is known is that he couldn't have possibly worked on every one.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. Last edited by manbridge 74; 02-02-2014 at 02:26 PM.. |
I always thought 2.7 owners should have gotten a class action suit going against Mr. Anderson He pretty much destroyed the value of everyones' 2.7 for 25 years.
The funny thing is that none of the 2.7 fixes are difficult, or even particularly costly. All the models have had their issues over the years. How many of you guys remember the mysterious oiling/temperature issues when the SC was introduced. Porsche replaced more than a few (statistics?) brand spanking new 3 liter motors before that one got figured out. Jeff, I am impressed that you have no pulled threads on your original motor. Figured they had all been done by now. Last edited by Daves911L; 02-02-2014 at 02:26 PM.. Reason: afterthought |
I have a 7R mag-case 2.7 that I rebuilt with all the "fixes" (time-certs, OE steel head studs, line bore, planarized spigot mounts, oil bypass mod, bigger oil pump, added front cooler, followed Supertec's excellent case-sealing advice, hydraulic tensioners, turbo covers, lots of balancing, etc). It was not an inexpensive rebuild. I rebuilt this in the stock CIS configuration and the thing has plenty of power and pull. Not a single leak or oil drip. I'm very happy with the result. (Now if I could just get the rest of the car sorted appropriately...)
Science is NOT optional
One thing about the 2.7 vs 3.6 discussion that only rare comes up is the spirited character of a sporty 2.7. Yes a 3.6 has more horsepower, more torque, etc but, as an owner of both I have to say that the 2.7 just loves to spin in a way that the larger displacement motor doesn't. Maybe with a bunch of work a 3.6 will do it too but the 2.7 is a real blast.
I bought mine from a good friend who sold it because the motor was on borrowed time and figure that I'll refresh it one of these days. Meanwhile it has already had the bulk of the updates and although I don't race it I have enjoyed relatively problem free sport driving for 20 years. That's 20 years since he thought it was about to blow. I change the oil etc and that's about it. It gets parked when the snow flies. It hasn't been a ton of miles but I have driven it back and forth from Utah to Oregon and would not hesitate to do so again.
PCA member since 1993 |
Thanks again guys.
1985 911 Targa (sold) 2001 996 Twin Turbo (sold) 2001 996 C4 |
Sugar Scoops Rule :)
I've owned my 76 since 1984, engine has never been rebuilt. I bought it from the original owner in San Diego, who very wisely removed the thermal reactors and installed an 11 blade fan and front mounted oil cooler. It continues to be a blast to drive.
I'm sure it will need a rebuild at some point, and I plan to do all of the 'correct' fixes noted previously, to keep it 'numbers matching'. Having driven quite a few other later 911 models, I also think the combination of the 2.7 w/ the light 'middie' body and lack of modern 'extras' make these cars great fun. And easy to work on.
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
Projekt Rostlaube
I'm new to the 911 crowd and currently restoring a '74 coupe - what kind of gas mileage do you all experience from these engines? Just curious...
"Kid in a candy shop"
I get an average of 20 mpg.
I'm curious to see what others get. |
Projekt Rostlaube
Im running carbs and avg around 16-18mpg.
1976 911S MidYear Fever is alive and well. |
Projekt Rostlaube
I always look forward to adding my 2 cents to these mid-year discussions. I bought my stock 1976 911S in 1983. I believe the original owner had valve guides done. Other than that the engine has had no internal work. I've done several external upgrades (74 SSI's, 11 blade fan, front oil cooler, hydro tensioners, etc). Only '76 California cars and all '77's had thermal reactors. The poor Calif cars have to keep their reactors on to pass inspection. Do ANY other 2.7's still have reactors?? Mid year cars are lighter and narrower (autocross!) than SC's and they pull like a diesel at low rpms.
About 20 years ago I wrote a letter to Bruce Anderson after he authored another article trashing the 2.7's. My point was that if they were really that bad (those cars were already 20 years old by then) haven't they already failed and been fixed? Or, if they hadn't failed yet, how much longer did they have to last for him to finally bless them? Bruce wrote back with a defense of his recommendations. A real gentleman whom we all miss. Anyway, my argument is even more to the point 20 years later. Yes, my 911 leaks about two drops/week, starts every day, never lets me down and is an autocross winner. It's the most rewarding purchase I've ever made. YMMV!
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
Straight shooter
Probably fewer failures today with the updates on many remaining examples and the few survivors aren't tracked without updates like the examples back in the days Bruce saw with so many issues.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
My '77 had a rebuild (P/O) about 8,000 miles ago. I have owner this car since 2010 and drive it a lot. I enjoy it just way she is and it has plenty of power. Since I like going through the gears the mileage isn't that great. I think I am around the 15-18 mpg range. I have driven other newer and older Porsches but I come back to mine and like it very much.
'77 Porsche 911S |
