Lees73Super's Avatar
Turn signals don't signal
Trying to help out a buddy with an 86 targa. His emergency flashers work fine. When the car is off and you flip the turn signal, that side lights up as designed for curb Parking, so it seems the column switch is ok. But they won't flash once the key is on. Is there another turn signal relay seperately from the emergency flasher switch that could be kaput?
Thanks!
Old 02-08-2014, 07:32 AM
911 SC 1980
Esa911sc's Avatar
If I remember correct there is a fuse for each blinker but if even one them is gone none of the blinkers won't work. Emergency blinkers work despite of burned fuse.
911 SC 1980 Regularity Rally Car
996 C2 2000 Daily Driver
Cayenne 3,6 2011 for wife and lab
924 Targa 1982 Sold!
Old 02-08-2014, 07:38 AM
Thanks, fuses are checking fine.
Old 02-08-2014, 07:45 AM
porwolf's Avatar
I don't know about the '86 model. But according to my '78 to '83 Bentley SC manual there is a "Turn Signal/Flasher Relay" located behind the instruments:
Then there is a reference to a "Turn Signal Flasher" in a Component Location Table. The location of which scould be "In luggage compartment left rear, in front of power window relay"
Both references are probably for the same turn signal flasher relay.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-08-2014, 04:15 PM
