Turn signals don't signal
Trying to help out a buddy with an 86 targa. His emergency flashers work fine. When the car is off and you flip the turn signal, that side lights up as designed for curb Parking, so it seems the column switch is ok. But they won't flash once the key is on. Is there another turn signal relay seperately from the emergency flasher switch that could be kaput?
Thanks! |
911 SC 1980
If I remember correct there is a fuse for each blinker but if even one them is gone none of the blinkers won't work. Emergency blinkers work despite of burned fuse.
911 SC 1980 Regularity Rally Car 996 C2 2000 Daily Driver Cayenne 3,6 2011 for wife and lab 924 Targa 1982 Sold! |
Thanks, fuses are checking fine.
I don't know about the '86 model. But according to my '78 to '83 Bentley SC manual there is a "Turn Signal/Flasher Relay" located behind the instruments:
![]() Then there is a reference to a "Turn Signal Flasher" in a Component Location Table. The location of which scould be "In luggage compartment left rear, in front of power window relay" Both references are probably for the same turn signal flasher relay.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
