Will this damage the shaft or CV joint?
moving this to a new thread because the challenges keep evolving… Now trying to remove the rear hub to get to the bearings. Can't figure out a way to get leverage so reinstalled the drive shaft and prepared to use a puller. Just not sure this looks right. Am I going to damage the shaft or CV joints? Doesn't seem right...
Old 02-16-2014, 10:28 AM
French Import
zippy_gg's Avatar
Stop! You should not push on the drive shafts to remove the hubs!
The pressure needs to be applied on the bearing race instead.
From my recollection and working on my 86 I removed the drive shafts, first from the transmission side, then from the hub side.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-16-2014, 10:30 AM
Yeah, doesn't seem right. Thanks. I will remove the shaft again but just can't get the hub off.
I have a couple pullers, but nothing to pull against. I am reduced to hitting the hub from under the car and making no progress. Must be missing something.
Old 02-16-2014, 10:33 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 what Gilles wrote.
'85 Carrera Targa
PCA/POC
Old 02-16-2014, 10:34 AM
out of options
That hub is not moving. I am using a bearing press and a hammer on the inside. I am using two pry bars on the outside. I am damaging the bearing but nothing is moving.
Any ideas? I just cannot hit it hard enough to move it.
Unless I am missing something, I have to consider putting the suspension back together and getting the car towed to a shop...
Old 02-16-2014, 11:42 AM
steely's Avatar
I am interested also (first time CV work in my future).
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-16-2014, 11:48 AM
76 911S Targa
The hubs come out like on a VW. According to my repair manual, you need to find a piece of pipe or other cylinder the diameter of the hub but smaller than the bearing through which it is pressed. I have used an impact socket of the proper diameter. Then drive out the hub from the inside by pounding the hub through the bearing. On a VW, we just remove the entire control arm or spindle and press it out with a hydraulic press. VW recommends a 20 ton press if this helps you envision the force required to remove the hub from the bearing. Light tapping will not do it. It requires a two pound (or larger) hammer and a good solid tool to place against the inner part of the hub. Big muscles help. I recommend a teenager do this for you.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 02-16-2014, 11:54 AM
French Import
zippy_gg's Avatar
One of my hubs came with using 2 24 inch pry bars and a second set of hands to stabilize the bars where they needed to apply pressure. No go with the other side so I used the Home Depot made up tool...
Then I had remove the half bearing left inside the trailing arm, again using the HD tool...
Gilles & Kathy
Old 02-16-2014, 12:06 PM
If i use the HD tool, aren't I pulling the inner hub against the outer hub?
Old 02-16-2014, 12:38 PM
I added this to your original thread:
Did a search and found this in a post by John Walker (he knows his stuff!). I and many others have used this method and it works!:
the bearing tools won't pull the flange out. only the bearing. i don't know of anyone that makes that tool. it would be nice to have one. i use two three foot long snapon prybars,(looks like a long, square shaft screwdriver with a bent end), one on each side of the flange, with the tips on the bearing retainer, and yank it out. it takes a bit of effort, but usually gets them. if the car is on stands, be careful to not pull it sideways. even the ones that won't budge by pounding on the backside generally respond to this method.
EDIT: here's a link to two of many threads with the same flange problem you have
How to remove rear hubs?
Rear Wheel Bearing Removal
_
_
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 02-16-2014, 01:05 PM
Here's a pic of the Porsche tool and method:
Removing stub axle nut
Old 02-16-2014, 01:38 PM
pors1968's Avatar
Buy or rent slide hammer puller for axle .
Old 02-16-2014, 04:58 PM
Boy... the $350 I paid a shop to do my rear wheel bearing was totally worth it!
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-16-2014, 05:07 PM
