Flojo's Avatar
SC backdate - bodywork questions
Sorry, guys, that I take liberty in opening yet an other "SC-backdate-thread", but I believe to have gone through all of I could read here at Pelican but stil cannot make up what I believe to miss in details.
I dig the longhood-look, but cannot aford a genuine one.
And my SC is well sortet and the SC-model has lots of advantages (e.g. brakebooster).
So I'm looking for a pictured bodywork tutorial (cut, set, weld, fix).
Please, can somebody explain to me with pictures, as to what has to be cut/modified, meaning: at what place exactly cuts have to be made?
I'd like to start with the rear.
I found this picture, looking like step one.
But what comes afterwards?
And how do you fix e.g. a fiberglass pre-74 bumper?
And then there is the front.
I know I'll need F-model fenders.
But how do you relocate the traverse for the longhood?
Many thanks for your asistance!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-28-2014, 04:00 AM
pors1968's Avatar
Just spot weld and is little weld each side .Rear crossmember is the same 65-89 .parts number 901 507 080 01.Easy job.
Old 02-28-2014, 04:06 AM
Flojo's Avatar
I plan on using this type of parts
rear
front
Old 02-28-2014, 04:15 AM
pors1968's Avatar
Front and rear bumper you have to make braket because you have SC
Old 02-28-2014, 04:18 AM
Here are a couple thorough threads on backdating.
This one was performed with reversibility in mind.
Light weight image change - Body Overhaul Projects - Impact Bumpers
This one is very thorough, performed by a gentleman who restores longhoods regularly.
My Backdated Hot Rod Project is Underway!
This one is being performed by a 911 artisan.
Cheap long hood...Another back date project
Old 02-28-2014, 06:17 AM
jittsl's Avatar
The rear bumper you already seem to have figured out. Drill the spot welds out and remove the piece that you have shown in your red line.
The front is easier if you use a fibreglass hybrid front hood. Most of the fiberglass guys sell one - they have the outer shell of a long hood and the inner structure of a short hood which means you can achieve the look without having to change the latch plate or the front of the chassis. The front bumper is simply a matter of adapting brackets to suit after you have acquired new finders.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 02-28-2014, 06:27 AM
Craig T's Avatar
Getty Design sells a very nice long hood conversion hood. Bolts right on. Nobody would ever know unless you open the hood. It's a very cost effective option.
Craig T
Old 02-28-2014, 07:24 AM
