gjs
brake caliper piston insertion
Hello: Am rebuilding my 88 911 calipers. All clean, soaker inner seal in brake fluid, have the lub our host cells, 20 deg angle but cant push piston in. Any techniques for those before me. Press them in?
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff 2015 Cayman S 1948 Willy's Overland Jeepster 2013 Chev Sub 2004 Nisson Xterra |
gjs
just got one piston in with more lub less brake fluid.
abides.
A press is ok, but if you can't press them in by hand you probably dont have them going in straight.
Graham 1984 Carrera Targa |
gjs
It is straight. With finger pressure I can piston it in and out about 1-2 mm. Hear a suction in line intake when I do it. It just does not want to pass the seal.
gjs
Wiggled back and forth with a vice grip on safe part of pistion while pressing in. It is the outer ring that is the next challenge
Home of the Whopper
I use a c clamp.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
gjs
that helped. Am now going round and round trying to push outer seal on the rear. Front was easy
A c clamp with a socket inside the caliper works well
abides.
Graham 1984 Carrera Targa Last edited by gtc; 02-28-2014 at 03:45 PM.. |
