87 911 3.2 cabrio widebody, autothority maf, no cat.
My car is horribly running, rough, low on power from 2k to 3k then 35 to 4k but then it clears, done a cap, rotor, 02 sensor, all fuel system gone over, alarm removed, tank cleaned, plugs, alternator checked out, not sure where to go now. ![]() Please help |
ignition leads?
82 SC Targa Guards Red = Toy 04 E55 AMG Brilliant Silver = DD 04 Cayenne Turbo Platinum Grey on 22s = Previous DD 80 Wide body 12AT RX7 Black 350+ hp= Previous Toy 78 Alfa Romeo GTV Blue = My 1st Cool Car |
nope
Does it have the stock barn-door AFM or an aftermarket conversion with hot-film sensor and modified DME? I assume it's the later when you say Autothority. I believe the kit is a modified chip (accounts for the different response function of MAF), a hack in the DME (power to the MAF) and the MAF itself.
Then your Garage says it has an electric Turbo?! - can you elaborate What changed or was it always running terrible like this? Was the change gradual or sudden? Do you have the stock parts and can you put them back? (you need a stock DME & AFM) If not my first guess would be something on the conversion went bad and you are stuck with replacing it on a hunch. The filament in these sensors can become contaminated with time giving wrong readings. Depending on the model used some have a self-cleaning function (heat up wire real high on start to evaporate contaminants) but others don't. Not a good position to be in.... Next the usual suspect that affects mixture: vacuum leaks. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
So does anybody have any more ideas as to what it could be, i'm getting to the point where i'll take it to the crooks in town at the porsche shop
Double check you plug wires and firing order.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Check the idle microswitch. Its located on the throttle body, and it tells the DME that the throttle is closed. Sometimes when they go bad, they get stuck in throttle closed mode, effectively telling the DME the throttle is closed, even though you are pushing on the pedal. I believe the WOT switch overrides the idle switch. How does it run under Wide Open Throttle?
The classic symptoms of a bad idle microswitch are. Engine idles fine. Engine runs fine at Wide Open Throttle. Any other throttle position results in bucking, running rough.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold Last edited by DCinVA; 03-04-2014 at 01:56 AM.. |
coil?
Here is a simple test for the secondary wiring (plug and coil wires).
Wait till dark. Turn off all the lights. Open engine lid. Fire up engine. Visually inspect for small lightning bolts. If you see any sparks at all, replace the secondary wires.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
