SLR
Speed referance sensor fittend
Hi and Good Weekend,
Well had The faulte Sensors replased To Day After One went caput, Car Runs well and Reely quick on The throtal, sensitive . But on ideal The Engine Revs oserlates a Bit like when Cold , though dose Not setal down. If I blip The Pedal when war it wil Run even. I'v cheked The turmanals, all ok there, I can't work it out, if some One could add an Indea Thanks Steve |
Hi
You need to be more specific.
Exactly which sensor did you replace? And confirm that you are working on the 3.2 that you have in your Garage.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Did the weekend start out in a pub by any chance?
Rick 88 Cab |
SLR
Nup no Pub don't drink. Pridictive Text on this Thinge sucks.
The Car is a 3.2 1985 Euro. The Sensors are The two in The crackcase, To The Fly wheel. I thought I did. Sayn they are The Impuls/speed referance sensor, thats what The invoice says. |
Maybe check the idle control valve (ICV). Remove and clean perhaps.
Did it run really well before you replaced the sensors? What led you to do that? / Why did you replace the sensors? Did it stop working well after you replaced the sensors? give us a bigger feel for the situation beyond your current problem if you wouldn't mind please. You could have a prob with the ICV being dirty as it tries to compensate , or you could have a bit of an air leak. Does it run better after she warms up. tnx
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Start by setting the base idle by installing the jumper and making sure the base idle is 800 rpm. Make sure the micro switch on the throttle body is set correctly.
Idle stalls when oil fill cap is off Idle speed adjustor If the idle does not drop when oil cap is removed, possible vacuum leak. Might also want to look at the cylinder head temperature sensor. Original single wire can cause problems, newer ones are 2 wire for better gound.
Ed 1973.5 T |
muck-raker
if a throttle blip corrects the problem, you may want to look at a quick lubrication of the portion of the throttle linkage located at the transmission housing.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
SLR
Steely, the car was running well as normal, turned it of then about 10 minutes tried to stat it, it turned over ok but would not fire up. my Porsche workshop is only about 300 meters away, got a tow. ended up that one of the sensors was toast! so replaced both. there the ones in the crank case to the fly wheel. It seems that they are called different names in different parts of the world.
E sully, thank you, what you suggest makes good sense, I will give that a go in the morning, oops it's morning now. |
