| weekend wOrrier Join Date: May 2011
			Look what just got posted in the classified section for cars! Based on this design, I'd suggest more zip ties! Is this ducting off a shop vac?   Last edited by LEAKYSEALS951; 03-10-2014 at 02:57 PM.. | ||
|  03-10-2014, 02:54 PM |
| Registered Join Date: Mar 2008 Location: Pittsburgh, PA
			Hey Jack, here are a couple solutions I found looking around. This isn't the prettiest, but the parts could be found here pretty cheaply, and would lose the weight.  Source: Heat in mid year (74) with a Varioram This is by far my favorite, but would involve some creative methods to access the rear tins of the engine if the engine isn't pulled.    Source: 3.6 Conversion - Cabin Heat Set-up | ||
|  03-11-2014, 03:54 AM |
| Registered Join Date: Jul 2002 Location: Atlanta
			Yes - that last one is the hidden heat set up very stealthy, clean and light.  Also not terribly expensive or difficult if you could attach the heat nozzles to the engine tin your self.
				__________________ erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD  RSR look hot rod, based on 75' SOLD  73 911t 3.0SC Hot rod Gulf Blue - Sold. | ||
|  03-11-2014, 05:22 AM |
| Registered |
			Love that rear heater outlet setup. Very clean! One consideration: usually cyl 3&6 (2 at rear) run slightly hotter not sure if pulling air off at those 2 points will make things worse?
				__________________ Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible | ||
|  03-11-2014, 05:29 AM |
| Registered Join Date: Oct 2013 Location: Prescott, AZ
			The 964 uses a piece of stainless tubing for the air crossover, so the P engineers must have had so me reason to spec a cast piece for the 993. Extra heat in that area compared to the 964?
|  03-11-2014, 05:32 AM |
				 | Quote:
 A 964 uses a similar exhaust as an SC or Carrera, the exhaust wraps around the back of the engine, combines at a crossover pipe, and the cat runs along the exhaust valve cover on the driver's side. A 993 has a true dual exhaust with a crossover section at the front of the engine with 2 cats right below that cast part. So there is significantly more heat there on a stock car. | ||
|  03-11-2014, 07:04 AM |
				 | Quote:
 I would think that it would help. You are forcing air past an area where it would normally hang around. | ||
|  03-11-2014, 07:09 AM |
			"I would think that it would help.  You are forcing air past an area where it would normally hang around." I was thinking the same thing...hmmm I wonder if it would be something to consider for earlier 911s?
|  03-11-2014, 09:06 AM |
| Registered Join Date: Oct 1998 Location: Denver, CO
			I bought this piece from Patrick motorsports.  It should work for me, although it won't be the cleanest install. I will use SCAT hoses, but the v-ram intake interferes. It will be tight... I have the big cast aluminum manifold as well, but it am using the older engine mount with an m&k muffler, all bolted up to stock 993 heat exchangers. The muffler doesn't leave room for anything else back behind the bumper...
				__________________ - '72 911T - '81 911SC Euro | ||
|  03-12-2014, 06:04 AM |
			Also still working on the exact plumbing with silicon reducers, couplers, etc. http://www.siliconeintakes.com/index.php?cPath=14&osCsid=05d2cf8f9cb4e52ed62ba355d0b878f3
|  03-12-2014, 06:08 AM |
