Scott S's Avatar
I know it is not the best location, but is it cheesy? Third brake light
Hi All -
I was thinking of converting the rear fog light on my 77 to an additional/third brake light. I know the location is not great, just looking for some additional awareness without altering the car (adding an additional window mounted light).
Thoughts?
Thanks -
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 03-10-2014, 12:15 PM
OffCamber00's Avatar
Not cheesy - just not sure how useful. What is the driver for a third light anyway? Are the other two broken?
Mat P
1988 911 Carrera
Old 03-10-2014, 12:17 PM
Driver, not Mechanic
IIRC the third brake light was for trucks who are high up and may not see the regular brake lights when they are close. So since the fog light is at the same level I don't see it working for that purpose.
Which set of drivers were you planning to make more aware?
Old 03-10-2014, 12:21 PM
Flojo's Avatar
... and it does not fit the design of an early-up-to-89-911 at all (thumbsdown)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-10-2014, 12:25 PM
Scott S's Avatar
Nope, they both work fine. Just a level of paranoia. Our brake lights just seem so small compared to everything else on the road, and I would like to drive the car more regularly this summer (to the office, etc). My commute is 45 minutes and not on anysort of highway - all stop and go.
I was actually going to see if I could modify the rear fog by adding an additional bulb (or a dual element socket/bulb) so I could retain the rear fog function if needed.
I dont know - just thinking out loud......
Old 03-10-2014, 12:28 PM
Air Cooled
Craig_D's Avatar
Hi Scott, I've replaced my rear incandescent bulbs with very bright LED bulbs, and have also added an electric/mechanical brake light switch (instead of the slow acting hydraulic brake light actuator).
I've found that more people are paying attention to my car now, and I can wake them from their peripheral vision method of driving.
I have some links for these I'll look for.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-10-2014, 12:41 PM
How about
On the back of your helmet!
Old 03-10-2014, 12:44 PM
Air Cooled
Craig_D's Avatar
Here's my mechanical brake light switch THREAD
Here's a video of the LED turn signals, and the LED rear running lights (No brake light actuation)
Video 1
Here's a night time video of the LED turn signals, and the LED running and brake lights:
Video 2
'69 Honda CL350
Old 03-10-2014, 12:46 PM
wwest's Avatar
I retrofitted the '88 style High mount brake light to my 78, simple job.
Old 03-10-2014, 01:26 PM
Reiver
Reiver's Avatar
Source for the led lights?
Old 03-10-2014, 01:58 PM
these days ..
folks are looking for the light- bar..
tail-lights are so..
confusing.. is what they mean to say, but won't..
have one & it's saved the P numerous times..
Rika
Old 03-10-2014, 02:00 PM
Air Cooled
Craig_D's Avatar
Fellow Pelican Etarga is your man, and who I bought mine from.
At the tail end of THIS THREAD, you'll find tons of the LED discussions from brake lights, to turn signals, and LED Gauge lights.
'69 Honda CL350
Old 03-10-2014, 02:16 PM
Banned but not out, yet..
RSBob's Avatar
I used the fog as my third brake light back in 1980. Then I read that the reason the 3rd brake light is so effective is that they are pretty much at eye level and are hard to ignore. So then I ditched the fog brake and moved to a very small high intensity LED strip which is not really visible when not activated. Solution found. So you may have an alternative but chances are its ineffective unless it is aimed right into people's retinas
Old 03-10-2014, 02:35 PM
Hi Scott,
there are lots of LED third stop lights available for high up inside the back window - trouble is most either stick (or come unstuck) from the glass, or require attaching (irreversibly) to the car itself. I didn't want to alter the car in any way, so I bolted a tiny aluminum extension tongue to a 'bolt-on' LED unit, and just slipped it under the top of the rear window seal. I ran a couple small wires into engine bay via the access tube used by the rear window heater, and T-ed into the stop light wiring.
hope this helps,
Algernon
1982 911SC Wine Red Metallic
OMG I love this car!
Old 03-10-2014, 03:24 PM
