3.2 conversion - the tach works until the lights is turned on
Hello great forum!
I have a 74 with a 3.2 from 87 - builded in the US some years ago - now in Europe.
I just had all the gauges out to paint the dashboard.
Now installed again all gauges seems to work, but the tach goes dead when I turn on the lights. The motor still runs, no problems there...
At the terminal switch at the back of the tach I have black/violet in pin #2 and red/black directly below (I guess that is pin #5). However, I have no brown wire (ground) for pin #6 and as far as I know - never has been. There was a loose black wire (not connected to anything) when I took the tach out. I thought this was for the upshift-light and therefore this could (and should) be left hanging.. But I could be wrong.. Could the black wire actually be ground?
How do I check this?
And if so - I guess it goes to pin #6. But is #6 bottom-right or bottom-left?
Is the order: First row: 1 2 3 (last pin not used)
Second row: 4 5 6 (last pin not used) OR 6 5 4 (last pin not used)
(I know it is probably on the back of the tacho - but it is real hard to see...)
BTW: I also had a new Steve Wong chip installed while the gauges were out - but I guess this could not affect my tacho-problem since the engine seems to run smooth?)
Hope anybody has some ideas...
Thanks!
Regards
Tom
Old 03-23-2014, 05:17 AM
E Sully's Avatar
You definitely need the terminal 6 Brown ground wire to the Tachometer. I don't have a tachometer to check the pin order for you.
Black upshift wire can be left out.
Ed
1973.5 T
Old 03-23-2014, 05:53 AM
Thanks E Sully... I will go check tomorrow after work if the black wire is not actually ground. I think it might be - then it is just to hook it up to pin #6... You have to be a little lucky sometimes I guess!
Will check the tach if #6 is to the left or right to #5 - hope I will be able to see it on the back.
Happy driving...
Old 03-23-2014, 12:20 PM
E Sully's Avatar
The black wire should go to the DME connector, pin 11, to operate the upshift light.
You need to find the brown ground wire that is shared by the instruments and jumps between.
Ed
1973.5 T
Old 03-23-2014, 12:55 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by thobri View Post
... Hope anybody has some ideas...
Tom
What Ed said and a photo or two of your car
Welcome to PP and the madness.
Who Will Live... Will See
Old 03-23-2014, 02:16 PM
I will get that sorted asap… Won't make it today after work though.
Here is a picture of the car - but I am in the progress of changing several details in and out - will post pictures when finished.
Thanks for the help and welcome
Tom
Old 03-23-2014, 11:30 PM
Checked the black wire today. It turned out that it was actually ground. So I hooked it up to terminal #6 and fired the beast up. Everything works now!
Great - thanks for your help Ed.
Tom
Old 03-25-2014, 11:26 AM
JJ 911SC's Avatar
Tom
Great, we need a front shot
Old 03-25-2014, 01:50 PM
muck-raker
kidrock's Avatar
holy cow, that is a sweet ride.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 03-25-2014, 02:12 PM
