Carmagic.us
rothaus's Avatar
Originally Posted by PatrickM View Post
So I installed the Vintage white bulbs and love them. However, after driving the car, I discovered that the red light at the top of the oil and temp gauge will not go out and my parking brake lamp stays on as well. These didn't use to be a problem and functioned as expected.
That is strange.
You did not install any LEDs in your oil and temp gauge and parking brake lamp ?
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 05-16-2020, 12:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
Sthe red light at the top of the oil and temp gauge will not go out
Looks to me like you've put an LED in the very top warning light hole. That was added as an "overheat" warning for the Sportomatic transmission (which shared the engine oil), through at least the middies and up through the 1980 SCs.
What is this gauge light for?
Indicator Light Question
3rd light on the druck press guage
The hole for gauge illumination is level with the 2nd warning light and to the right of it as you sit in the driver's seat; or on the left, with the gauge face down in front of you - marked #2 in this photo of the back of the instrument porwolf posted:
'77 S with '78 930 power and a few other things.
Old 05-16-2020, 01:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
PatrickM's Avatar
Thanks. Yup, duh, when I inserted the bulb holder back into the gauge, I put it in the wrong hole. Ha.
Fixed and thanks again.
Great lights, work very well.
-Patrick
Old 05-16-2020, 01:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
Carmagic.us
rothaus's Avatar
-Patrick
Great !
It's always good when it's a simple fix.
Cheers
Engelbert
Old 05-17-2020, 04:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
NathanR's Avatar
Send a message via Yahoo to NathanR
Subbed
87 Carrera Coupe
Black on Black, H4 Headlights, Nurburgring Sticker
Old 12-06-2020, 07:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
PRE-H20's Avatar
BONEHEAD question......
Hi Fellas.......
Can someone post a picture of WHERE this bulb plugs into?
Back story to this post is:
Recently did some detailing an poked around UNDER the dash............ I ended up finding THIS (circled bulb) in the driver side floor mat..... at the moment I didnt really think about it but thought it was odd to randomly find a bulb on the floor mat.
FAST FORWARD A FEW WEEKS........
I drove me car at NIGHT and noticed my instrument panel DID NOT light up.... my headlights were on just fine, so were my running lights. I thought maybe the dimmer got moved during detailing, it was not, no lights on panel.
As I started to get anxious about ANOTHER project.... I remembered I had found that bulb on the floor mat. It is odd that it would randomly fall out but I thought it may be the issue......
I just need to find where the bulb get plugged into.....
Thats my request.... can someone post a picture of WHERE it need to be plugged into?
My instrumentation panel has always worked with no issues...... Since I drove it at night, I noticed the lights were out... otherwise who knows how much time would have gone by as i normally dont drive the 911 at night......
I know its the original type bulb, I know there are options to replace and improve..... (maybe down the road) I am just looking to get my light to work again)
see attached picture......
Old 04-30-2021, 11:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
PRE-H20's Avatar
Also...... since the lights to the speedo/tach/clock/fuel gauge all stopped working..... maybe the fuse went out.......
I need to check the fuse 1st I guess.
Where is this fuse? the panel in the Frunk? which one?.......
Help please.......
Old 04-30-2021, 11:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
Carmagic.us
rothaus's Avatar
Originally Posted by PRE-H20 View Post
Hi Fellas.......
If you have all original bulbs in you gauges, most of the bulbs look like the one you circled, depending what year your car is.
The best way to find out is to pull out the gauges and look. There must be a socket hanging out where the bulb belongs to.
Old 04-30-2021, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
Carmagic.us
rothaus's Avatar
Help please.......
There is no fuse for the instrument lights in the 911. The power comes direct from the light switch 58a, see image below (from another post here at the forum). That's why I recommend to add a fuse between the light switch and the instrument lights.
This could be the light switch, or the wire from the switch to the instrument lights is not connected. There must be a black/blue wire connected to terminal 58a. Or the bulbs are do dim that you think there are not on.
Cheers
Engelbert
Old 04-30-2021, 01:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
PRE-H20's Avatar
I have a 74 911
All original bulbs in panel.
Ok got home.
Started to poke around.
Checked things out, carefully....
No blown fuses.
Dimmer was turned off.
Turned dimmer on now and 4 of the 5 gauges turned on!
The speedo illumination light did not come on.
Other lights on speedo DID come on.
Sooooo im 99% sure the illumination BULB is out on my speedo!
Anyone have a LINK to where I can get that particular bulb?
Old 04-30-2021, 01:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
PRE-H20's Avatar
Engelbert .... wow thank you......... there's quite a bit of information there and lots to consider..... I didn't know there was NOT a fuse for the instrumentation panel... wow. i think that project might be coming up (adding a fuse between the switch and the panel) NOT having one doesn't make a lot of sense even to a lightweight mech like me!
do you have a link or a place where i can get that PARTICULAR bulb?
Ebay is my friend.....
Old 04-30-2021, 02:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
Carmagic.us
rothaus's Avatar
I don't have the regular bulbs, but if you like to switch to LEDs and can see how fast you go: Carmagic, LED Lights for Classic Porsches
Fuse: Carmagic, LED Lights for Classic Porsches
Cheers
Engelbert
Old 04-30-2021, 02:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
PRE-H20's Avatar
i think i will switch over down the road... for now... i just want to find and replace this particular bulb......
can anyone help me find THIS particular bulb ? link please.......
Old 04-30-2021, 02:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
Hello, Are these still available for sale?
Old 10-12-2021, 02:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
deshetlr's Avatar
His website is active. The link is 1 or 2 posts above yours. PS they work great!
Old 10-12-2021, 02:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
PRE-H2O Those bulbs are BA7 . Google it, it is very common.
Here one vendor that sells those
Instrument Panel Gauge Led Bulbs Ba7s Midget Flange Based Bulbs 3898 327 328 330 338 345 367 376 381 382 387 Midget Bayonet Based Bulbs 330
Try Amazon, they sell those.
Old 10-13-2021, 07:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
Carmagic.us
rothaus's Avatar
Check out this video about the installation.
Old 01-18-2022, 09:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
I tried to add a comment to that video and it kept getting deleted. Odd.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 01-20-2022, 09:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
