Pelican Parts Vendor
Oops; I had forgotten about this thread. Results:
232323232-fp93232-uqcshlukaxroqdfv3-23--nu=3356-36---;2-WSNRCG=-f-4eeeg03g5i-76;d0-fch-6d495ef55g46ot1lsi by Team Illuminata Motorsport, on Flickr
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Carmagic.us
LED Lamps for Brake, Backup, Turning Signal Lights
I was asked many time if I supply also the LED's for the Brake, Backup, Turning Signal Lights, etc.
I have done some testing and here are some pictures of the bulbs. For the Tail lights. From left to right: Tail Light/Brake, Turning Signal and Backup, Side Marker. ![]() I have the left and right lights next to each other, the left with standard bulbs, the right one with the LED's. ![]() This would the set for the rear end per side. ![]() This is for the front per side. The left one is for Parking light and Turning Signal, the right one is the side marker. ![]() For the dom light I have these Feston LED's ![]() I plan to them available in a month or so. Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Slippery Slope Victim
Engelbert,
I take it you have tested the turns in regard to needing a different turn signal flasher. Please let us know as I would like to order a full set of LED bulb replacements. And, if you could perhaps you could post a few photos at night of the LEDs installed. Thanks
Mike² 1985 M491 |
Carmagic.us
Hello Mike,
I still need to test it with the new flasher, and also want to add the LED in the tach and make sure it all work together, so it can also be ordered as a complete kit. Thanks Engelbert
Carmagic.us
OK here we go.
I have now a complete set of LED's including the following: Front: LED for turning signal/parking light, and side marker. ![]() Rear: LED for turning light, Back up light, Tail light/Brake light, and side marker ![]() Dash indicator: LED's and wire setup, plus the correct flasher relay, and instructions. I will have these sets ready for sale in about 4-6 weeks for $175 per set. I will take pre-orders for the first 10 set's for $150 shipped. Thanks Engelbert
Uncertifiable!!!
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Carmagic.us
Thanks Engelbert
Carmagic.us
I took some pictures, these are all with bright white LED's.
I let the camera adjust for the light, so they maybe a bit off. Here are the front parking / side marker light. ![]() Rear Tail Light only ![]() Rear Brake Light only ![]() Rear Tail and Brake Light ![]() Rear Flasher ![]() Rear Backup Light, this put's out a lot of light. ![]() The red lenses look a lot lighter in the pictures than they look in person. As soon I get some red and yellow LED's for the tail/brake and turning lights, I will do another test, however, they way this looks with the white LED's I don't think that the red or yellow would make it look much better, but it's worth a try. Cheers Engelbert
Subscribed. Also a thumbs up for the gauge LEDs. they look/work great.
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
Uncertifiable!!!
Johan
Carmagic.us
I got some red LED's and installed them to see the difference. Amazingly there is a difference.
Here the turning signal with the white LED ![]() Here with the Red one ![]() So, I will have them available as follows: Front: LED for turning signal/parking light, and side marker. These will be white. ![]() Rear: LED for Tail light/Brake light RED, turning light RED, Back up light Bright White, and side marker RED ![]() Cheers Engelbert
Member 911 Anonymous
If I may suggest, amber for us with Euro Lenses.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Carmagic.us
The only other color is Yellow and Blue. I can get a sample of the yellow for the turning signal. If you are interested to test the yellow LED with your Euro lenses. I can send you one once I got it.
Cheers Engelbert
Be happy to and compare them against Daniel Stern's recommend Nickle Plated HONDA bulbs.
PMing you my addy
Uncertifiable!!!
I suspect that yellow will work well with amber turn signal lenses. Looking forward to the result.
Johan
I got some bulbs from etarga in Phoenix about two years ago. He didn't have exterior lights then. I am interested.
I have read extensively much of the numerous threads on LEDs, I purchased a set of the vintage instrument LEDs from EngleBert which I will install this weekend.
Now I'm exploring LEDs for the exterior lights; front turn signal/marker, rear brake, turn signal, backup and third brake. Another member on this forum Spoke has these elaborate LED boards with mounting replacements, which he has put considerable R&D into. This seems to me overkill, maybe I'm missing something. What if any is the advantage over what Englebert is offering with just single plug in LED replacements for the bulbs. I like simplicity and elegance. Has anyone considered both and chose one over the other? And why? I do like the idea of having brighter lights both front and rear, it's not an immediate concern been driving the car for 20 years the way it is, but something I will do in the upcoming weeks/months. I'd like to make an informed decision. Thanks in advance for your input. John
jwill911 Espresso brown metallic `87 Carrera Coupe (sold) Now living in Mississippi |
Hi Engelbert,
Are these available now or coming soon? I realized after posting my last message they are not yet posted on your website, and your last post contained the key word "will". I'll patiently wait availability. John
Carmagic.us
They on order now and I should have them on hand by middle of June. Sorry, but I want to make sure the LED are good and they work for the red and amber lenses. Again, Thanks for the input. Engelbert
