Motor problems- Need help!
One week ago, my SC was starting and running perfectly. On a cold start, the engine would turn over, gather itself briefly, then idle smoothly.
After not driving for 1 week, I attempted to start my car. The engine turned over and idled extremely roughly before quitting. Eventually I was able to get the engine to run at high RPM, but it stumbles badly at idle then stops running. While increasing the RPM's, the engine backfires wildly. It feels like popcorn under my foot. (I have a pop-off valve) Even after getting the engine warm, it will NOT idle. It feels like it is missing badly. The last time I drove the car, I added oil. Other than that, uneventful. Do I maybe have a fouled plug? (or two?) Any help would be appreciated. On a brighter note, the clock is now running perfectly.
Senior Member
How's the battery? Is it up to snuff?
Short of this all I can think of is something in the fuel settled down and into the lines and/or filter. Sorry not to be of more help, John
'78 Targa in Minerva Blue |
RETIRED
Air box leak....even with the pop off valve they can crack from flexing. The 3.0 in my 914/6 had the problem, little rhino snot fixed it up.
Battery is good. Air box appears OK.
Is it possible to cause this by adding too much oil?
Team California
As wonderful as the "help thy neighbor" spirit is around here, (especially when the reciepient is named Moses), these posts frequently remind me of a board game, "guess the problem".
All good technicians, whether automotive or otherwise, diagnose problems systematically. Even when they "think they know what it is". Start at beginning, ie. car has fuel, battery good, no banana in tailpipe, etc... There is nothing wrong with checking your pop-off valve if you have a couple of minutes to spare, but that probably won't be it. Before anyone thinks that I do not appreciate the mechanical help given around here, think again, but for it to be truly effective, the problem-haver must be able to perform at least basic diagnostic procedures and describe results. By 'turn over', do you mean start? Otherwise, it is like (forgive me here) a hot young chick saying, "my thingy is making a wierd noise", and every mechanic from miles around, (plus all non-mechanics), trying to help. Like three monkees trying to f**k a football. Sorry for the rant, I probably got up on wrong side of bed, and it is not directed specifically at this post, but has been bugging me for awhile. Without some basic common language and skills, AAA and a trusted wrench may be the best option, (and where you are heading anyways).
Denis |
Sorry, speeder. Yes, it starts and runs roughly and briefly before quitting.
And no, there is no problem with my "thingy" and there never has been or ever will be a banana in MY tailpipe.
Team California
OK, I'll play
It could be anything from a completely plugged fuel filter, (extremely rare), to a very large vacuum leak anywhere from brake-booster in front trunk to cylinder head, bad fuel, (unlikely but possible), to an ignition/electronic problem, (did you check relay under passenger seat?), to etc...
Hard to say w/o looking, basically you want to eliminate the simple things first, work your way up. BTW, you think that car could be over-filled with oil? It is very important to understand the oil checking procedure on these cars, and do not trust anyone else who is not a Porsche mechanic to do it for you. IF the car was overfilled w/ oil, it could make it run very badly. Check for oil in airbox, it is not supposed to be there. Good luck.
Denis |
![]() Did the problem start before or immediately after filling with oil? Open up the air box and see if you have any oil in there.
Chuck Moreland - elephantracing.com - vonnen.com |
Thanks. Will check the airbox for oil when I get home.
Hilbilly Deluxe
Out of they way, I want my turn at the football.
Your car is an 83 right? Do the dome lights work? If they do, see if the frequency valve is buzzing. Tom |
Dome lights?
They only wrk in the "manual-on" position. Never have worked when opening the door. What could the dome-light relay have to do with my problem?
Formerly bb80sc
Ok Moses,
this may sound really idiotic, but did you replace the oil cap? Leaving this off creates a gnarley vaccum leak. I only know this cuz I've done it ![]() -Brad 80SC |
Formerly bb80sc
-Brad 80SC Last edited by Vipergrün; 09-11-2002 at 10:04 AM.. |
Hilbilly Deluxe
Does the Frequency valve work (buzzing, or vibrating to the touch)? Tom |
Excellent starting points! Thanks for the help.
Moses (still searching, but no longer aimless )
Author of "101 Projects"
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
