As I previously mentioned, I verified that the fuel expansion tank in the front driver fender has an unobstructed hose coming into it thru the fender, however the fuel expansion tank just vents to fresh air there. It's supposed to have a line running back to the carbon canister but it was not attached and it seems to be clogged anyway, probably with carbon pellets. Could the problem be that my gas tank isn't under pressure? I dont ever hear pressure release when I take off the gas cap, should I? |
abit off center
You ever do a fuel volume check at the test port?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
