How many miles or km do you get
How many miles or km do you guys get to a full tank
I went for a long drive today about 100 miles city and 260 hwy so 360 miles to a tank on my 81 targa mind you my gas light came on went to the pump and put. 65 litres in it so I guess I still had 10 to 15 litres left
Old 03-30-2014, 05:34 PM
Fleabit peanut monkey
Bob Kontak's Avatar
You are at about half the MPG that the 81 SC delivers.
80L tank.
But at least you got some driving in.
What work have you done to address your idle problems mentioned in previous posts?
Anything?
Anything at all?
1981 911SC Targa
Old 03-30-2014, 05:44 PM
Rescuer of old cars
Arne2's Avatar
My 3.2 Carrera gets a full 300 miles in 100% city driving, far more on the highway.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-30-2014, 06:31 PM
My only idle problem is when I Start the car it surges for 5 min then goes away and idles normal
I haven't done much as I have some books on order from out host do I can start learning and troubleshooting this
I made a mistake on my original post I will edit I said 260 miles to a tank I meant to say 360 total 100 city 260 hwy
Old 03-30-2014, 06:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
With a clean or new air filter I get about 22-23 MPG but freeway only almost 25MPG.
You have a vacuum leak, check your hoses, probably after 5 minutes the rubber expands and seals the small leak just enough, but over time it will get worse after many expansion and contactions due to heat.
'85 Carrera Targa
PCA/POC
Old 03-30-2014, 07:20 PM
Bob Kontak's Avatar
Way better. To get 500 miles you have to drive like a wimp.
1981 911SC Targa
Old 03-30-2014, 07:31 PM
Bob Kontak's Avatar
You got potential. I am gonna work you real hard. It's going to hurt. But it will be a good hurt.
1981 911SC Targa
Old 03-30-2014, 07:33 PM
Thanks bob I have checked my vaccum hoses their all good it's a minor problem I'll take it slow as I get familiar with these engines thanks for your willingness to help and I will need it it runs fine after 2-5 min after warm up so in guessing a minor issue I will get to
Old 03-31-2014, 09:01 AM
On road trips I sometimes go 400 miles before I fill up. I usually wait until I am at a good location with fresh gas. Last year coming back from Michigan I waited until I got to my local favorite station to fill up because it is 100% gasoline. I went 490 miles on that tank.
Old 03-31-2014, 10:13 AM
I've got a '74S dual carb race car that gets a solid 15-17 mpg. If I floor it nonstop I can get it down to 10 mpg
On the other hand, my half fiberglass '77S gets 28/mpg on the highway going 60 mph in 5th which is very handy for road trips.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 04-01-2014, 09:58 AM
Bob Kontak's Avatar
60mph is the secret. On my SC, I drive 68 mph (which is a GPS 62mph) and get just over 25.
Plus no tickets.
1981 911SC Targa
Old 04-01-2014, 01:25 PM
Plus no tickets.
Bob:
If GPS says 62, and your speedo says 10% higher does that mean you should lower your mpg by 10% as well? I assume the 10% comes from tire size, etc. and affects everything, including odometer? Just asking.
Algernon
1982 911SC Wine Red Metallic
OMG I love this car!
Old 04-01-2014, 03:14 PM
IslandHopper's Avatar
Originally Posted by Algernon View Post
Bob:
Algernon
Well, if the speedo is off then yes the odo will be as well. Your theory makes sense, although it is off by 10% at 60mph, it would maybe only be off 5% at 30mph?? though, is that correct? lol.
BUT the odometer would be off a sepecific FIXED percentage.... however I'm not sure how you tell WHAT that percentage would be....
or am I over-thinking this and it would always be off by 10%..... yes that sounds right now....
Old 04-01-2014, 06:12 PM
Bob Kontak's Avatar
Bob:
Algernon
That's a good question. I only use the GPS miles traveled when on a trip as the odo is off as well.
When on a trip, the mile markers are easy to use as a guide. At a true 70mph the odo moves about 9/10 of a mile. I have not checked it lower speeds but I bet IslandHopper is correct in that it is fixed vs. variable. My car has 100k miles on the odo so it probably has 111k-ish true miles - plus or minus a few.
I did take the car on a speed run on the Ohio Turnpike. Slight downhill for about two miles. 138 on the speedo. Talking up a storm at work. Next time used GPS and it was 125mph when 138 was on the speedo. Sigh.............
So the speedo is linear in it's error from my case study of a couple of comparisons against GPS.
Your speedo is probably off as well. It can be corrected by the speedo places. They fix the odo as well. Saying this based on reading the error is common.
Note my 85 MPH speedo was replaced with a 160 mph speedo at the dealer in the way-back.
1981 911SC Targa
Old 04-01-2014, 06:39 PM
Bill Douglas's Avatar
I get as many miles to the kilometer as I get when I drive my Corolla
Old 04-01-2014, 06:43 PM
Formerly known as Syzygy
Canada Kev's Avatar
With that in mind, your has likely LESS than 100 K miles then (probably about 90K if your 9/10 ratio holds true), not more than what your odometer reads. No need to add more than she deserves...
Kevin
Old 04-01-2014, 07:32 PM
Flojo's Avatar
360mls for 65l is quite nice I guess...
with my 79 SC (930.06 engine) I get 440km (about 275mls) when the light goes on and refill aprox 63l.
much city driving involved... unfortunately.
thats about 14l average.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-09-2014, 05:58 AM
1988 Carrera
shadowjack1's Avatar
On my 88, I get around 400 miles per tank, 20 MPG +/-
Old 04-09-2014, 06:42 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Who cares, the bigger question is how many smiles per mile SPM!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-09-2014, 08:02 AM
OsoMoore's Avatar
~21 mpg city
~24 mpg highway
My favorite driving is back country roads, where I get about 22 mpg.
With the ginorous tank on the SC, I'll go 2+ weeks without filling up. And then, if the gas price is spiking, you have to swipe your card twice. Yikes!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 04-09-2014, 08:04 AM
