3 point rear belt conversion question
Hi folks. I feel like a fool here, but somewhere, I have seen a photo with measurements, on where to put the holes (and what shape) in the rear parcel shelf, to install rear shoulder belts.
I finally have all the parts (including the two "trim rose" pieces) but want to "measure twice, cut once" as they say.... and best I can do right now is eyeball pictures of the outside of the shelf with mounted trim rings and belts.
Anyone know where I can find this, or have a 964 or 88/89 Carrera they can measure for me?
-Glenn
Old 04-15-2014, 02:59 PM
Anyone? :-)
Old 04-16-2014, 07:02 AM
Jp-oh's Avatar
I did this not too long ago and did so without measurements. I used a template made from cardboard (as some before me had suggested). Mount the belts on the rear deck and cut a large cardboard panel to mock up the parcel shelf and figure your hole position and size on that then use as a jig to cut holes on the parcel shelf.
1986 Meteor Grey Carrera - We'll meet again in Valhalla.
Old 04-16-2014, 07:28 AM
Former Options Trader !!!
I just did this in my 1987. The if your car is a 1984 or later it will already have the threaded mounting points under the reardeck. You can remove the deck and easily measure yourself.
I live outside Philly, if you're near by, I used an old deck I bought off of eBay to make a stencil to plot the holes I needed to cut in my reardeck, you can have it.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 04-16-2014, 07:31 AM
Thanks. I'm in good shape with the hole for the screw - just have to hack up the parcel shelf.
That's a good idea on using a cardboard template.
Can I ask you folks - how close is the top edge of the hole to the "bend" in the parcel shelf? And, am I correct in saying that if the hole is properly cut, the trim will "pop in" and stay?
-Glenn
Old 04-16-2014, 07:34 AM
trader220, are you going to Hershey?
I live in central NJ, may be doable to meet - but might even be easier to meet at Hershey.
-Glenn
Old 04-16-2014, 09:49 AM
Jp-oh's Avatar
-Glenn
Here is a pic of mine. The rosettes sholud be able to stay put themselves in a reasonably cut hole. I think I may have gone with super classy high end black duct tape.
Old 04-16-2014, 10:12 AM
I touch of epoxy on the underside of the rosette. The factory had bendable fasteners but they had the luxury of doing before the trim was on the deck card.
I wont be at Hershey, sorry.
Old 04-16-2014, 10:44 AM
