Rebuilt Tach Not Working - What to Troubleshoot Next? (3.2)
Well, I sent the tach out of my '84 off to North Hollywood Speedo and had it repaired and calibrated. I plugged it back into the car and still no luck. I'm measuring 14.2V at pin 5 (I believe).
What should I troubleshoot next? I have access to an oscilloscope, could someone tell me what kind of signal I should see and at which pin? Thanks in advance Pelicans!
'64 Beetle '84 911 Targa '83 930 Last edited by kostya.lyt; 04-17-2014 at 07:15 AM.. |
Pin 2 of the tach (black with violet tracer) should have a 0-12 volt pulses coincident with the spark pulses per the Bentley.
Rick 88 Cab |
a varying voltage with the engine idling.
Dave |
with pin 6 at ground and pin 5 at 12 volts. The tach needle will move a little. If one connects a file to 12 volts and drags the pin 2 input on the file, the tach can be made to reach about 1K RPMs. The pins count from the rear left to right; 1-H on top row, 4-6 on the bottom row (tach upright).
Dave Last edited by mysocal911; 04-17-2014 at 09:32 AM.. |
After quick review of DME internal schematic you should see a nice square wave on the tach signal line. 0volts for a period of time, while it's 0vdc the coil is charging 'dwell time' then it should go to 12vdc while coil fires and waits for next charge to start. It looks to me like the wave will vary in duty cycle with RPMs.
The tach is driven from pin 21 on the DME so you can also check at the DME if need be. But with a good scope you should see decent square wave at idle but it won't be 50% off and 50% on at idle. At 1000RPMs it should be off (0vdc) for about 3ms followed by 12vdc for about 17ms. At 1000RPMs you have coil firing at about every 20ms and the coil dwells (charges) for about 3ms so 3ms charge + 17ms = 20ms. That's my educated guess from looking at the schematic. This also means you can bench test the tach with a simple 0-12vdc square wave generator.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 04-17-2014 at 10:50 AM.. |
of the DME ECM, i.e. the phase and duty cycle. With a resistive load vs a coil connected to pin 1 and 12 volts, the signals are basically identical.
Dave |
