"Kid in a candy shop"
O' yeah"74's Avatar
How much $ for spring plate bushing replacement
I did a quick search of the threads here but didn't find an answer. Could someone tell me what to expect to spend to have my rear spring plate bushings replaced, using neatrix bushings. Basically looking for labor cost of bushing replacement and wheel allignment.
Thanks in advance for your feedback.
Old 04-28-2014, 05:25 AM
kodioneill's Avatar
I would charge 2.5 hours a side + parts. $200.00 for a 4 wheel alignment.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-28-2014, 05:42 AM
O' yeah"74's Avatar
Thanks Kodi.
Old 04-28-2014, 06:54 AM
Dave Colangelo's Avatar
I did it my self in about 8 hours a bit longer than a shop but its actually not that hard of a job, a good shop may do it in 4 and they may (at least I would think a serious Porsche shop would) align the rear wheels as part of the job (or do it at a discounted price).
so lets say 4 hours @100ish an hour and $150 for the alignment, 550ish + parts.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 04-28-2014, 07:01 AM
O' yeah"74's Avatar
This is a job I would definitely be willing to do in the future, but as of now I have no good work space, so I'm limited. First things first, a garage with enough room to work in and scissor lift, then "I'm off to the races".
Thanks for the input Dave
Old 04-28-2014, 07:33 AM
I did it with out a lift and it was not terrible, but be prepared to sit on the ground for a few hours. The hardest part was getting some of the bolts off where the spring plate connects to the swing arm. they were really cranked down on and tough to break. One had even kind of fused its self to the swing arm. All in all once I figured out the tricks on one side the second side was much easier. Get the car nice and high on some jack stands and have at it.
I also did a good job of stinking up the house while burning the old bushings off...
Regards
Dave
Old 04-28-2014, 07:48 AM
moneymanager's Avatar
Depends a lot on where you live. About $750 labor two weeks ago in my town plus $250 for Elephant Racing's polybronze bearings; Neatrix are of course less. But if I'd bought the ER product six years ago when I last installed Neatrix I'd have saved the $750!
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-28-2014, 11:12 AM
E Sully's Avatar
What about a corner balance?
Ed
1973.5 T
Old 04-28-2014, 12:01 PM
Location: behind the redwood curtain, (humboldt county) california
As long as you are in there...
Is it likely that the inner arm pivot bushings need replacement?, if the spring plate bushings are bad?? Might as well do it as long as you are in there.
If the front end has been done recently, then it makes sense to do a corner balance and align.
chris
Old 04-28-2014, 03:05 PM
Yeah, you need to corner balance after that.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-28-2014, 03:24 PM
O' yeah"74's Avatar
Thanks for the feedback you guys. I will take all this into consideration and let you know the out come.
Old 04-28-2014, 05:38 PM
