Author of "101 Projects"
Another Problem...
Well, I've found many errors in the spec books, but I've just come across some missing information! Anyone have any idea where I might find the following valuable information?
Piston Top Ring - Groove Dimensions / tolerances - Ring Dimensions / tolerances - for all 911s 1975-89 Piston Middle Ring - Groove Dimensions / tolerances - Ring Dimensions / tolerances - for all 911s 1975-89 Piston Oil Seal Ring - Groove Dimensions / tolerances - Ring Dimensions / tolerances - for all 911s 1975-89 Cylinder to Crankcase Dimensions - Shaft - Bore Cylinder to Cylinder Head Dimensions - Shaft - Bore ??? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
the ring grooves vary between mahle and schmidt in the early years, and are mostly 1.5/ 1.5/ 4.0 in later years. the ring side clearance and wear limit is listed in section 1, page 6.1-4/1 in the 1st volume of the factory repair manuals. the end gaps are also listed on the previous page.
on the cylinder/crankcase dimensions, what do you mean by "shaft"?
Senior Member
Hello
Errors in the factory spec books ( typen, masse, toleranzen ) ? Most specs are covered and descriped in the factory manuals but you need the complete set from 65 on ( if something was covered in the previous volume it will not show up on later volumes, only if something changed ). Just look for the 0 sections ( technical data ) and for the spec section in each undersection. Grüsse |
Thanks - but I've scoured all of the factory manuals, and tech bulletins. They omitted this stuff from the later spec books...
-Wayne
Wayne? I think Roland may know more, when it comes to details of more than a few years ago, than 95% of the people at the factory....he's a valuable resource, methinks...
