Author of "101 Projects"
Wayne 962's Avatar
Another Problem...
Well, I've found many errors in the spec books, but I've just come across some missing information! Anyone have any idea where I might find the following valuable information?
Piston Top Ring
- Groove Dimensions / tolerances
- Ring Dimensions / tolerances
- for all 911s 1975-89
Piston Middle Ring
Piston Oil Seal Ring
Cylinder to Crankcase Dimensions
- Shaft
- Bore
Cylinder to Cylinder Head Dimensions
- Shaft
- Bore
-Wayne
Old 09-27-2002, 03:57 AM
the ring grooves vary between mahle and schmidt in the early years, and are mostly 1.5/ 1.5/ 4.0 in later years. the ring side clearance and wear limit is listed in section 1, page 6.1-4/1 in the 1st volume of the factory repair manuals. the end gaps are also listed on the previous page.
on the cylinder/crankcase dimensions, what do you mean by "shaft"?
206 637 4071
Old 09-27-2002, 05:42 PM
Senior Member
Hello
Errors in the factory spec books ( typen, masse, toleranzen ) ?
Most specs are covered and descriped in the factory manuals but you need the complete set from 65 on ( if something was covered in the previous volume it will not show up on later volumes, only if something changed ). Just look for the 0 sections ( technical data ) and for the spec section in each undersection.
Grüsse
Old 09-30-2002, 05:25 AM
pwd72s's Avatar
Wayne? I think Roland may know more, when it comes to details of more than a few years ago, than 95% of the people at the factory....he's a valuable resource, methinks...
Old 09-30-2002, 05:44 PM
